On this family of calculators, you do as follows
To convert this back to DMS, press [ANGLE][|=>DMS][ENTER] and the calculator displays the original value 15 deg 25' 32"
How can such a step by step, complete and exhaustive explanation fail to help you? If you can read and understand what is written you should be ab le to benefit from the answer.
If for some reason you cannot understand, ask for clarifications by posting a command to this thread.
Did you want to convert from D.D to DMS, read the last line of the post.
Did you want to convert from radians to DMS? You cannot! You have to convert from radians to D.D then convert the answer to DMS.
If you want to convert radians to DMS
If that is not what you were trying to do, I am afraid I cannot be of help, because the calculator does not have an application, or a folder called "LOST and FOUND".Set default angle unit to degree (see under [MODE]
Enter the angle value in radians and use the [2nd][APPS][3:raised R] to put the radiand unit and press [ENTER]
The result will be in Decimal degrees.
Press [SHIFT][ANGLE][4:ToDMS
OOPS posting a comment to this thread
