Nokia 7373 Cellular Phone Logo
Posted on Jan 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi there! I'm trying (unsuccessfully) to unlock my Nokia 7373 IMEI No 356291019994610. It is locked to Virgin apparently. Can anybody help? :( Thank you!
Anonymous
Level 3:
  • Master 5,081 Answers
  • Posted on Jan 11, 2010
Anonymous
Master
Level 3:
Answers
5081
Questions
Helped
2236297
Points
18738
You can do it by flashing your mobile if your mobile is a CDMA mobile...
The procedure for flashing your mobile is in the link below
http://hubpages.com/hub/How-to-Flash-your-cell-phone
It has an video explanation.
If yourmobile is not an CDMA mobile , you can get the network unlock code(NCK) byjust contacting the current network provider customer caredepartment.It is free of cost.
After entering in the reset code the phone requests for the security code av tired 12345 , 00000 , all av failed . wat is the security code for nokia 7373
- To unlock you Nokia 7373 (if forgot or lost lock code) you can unlock it using a master code. - To get the master code i need the IMEI code of your mobile phone. - With the help of
this IMEI code we can get the master code of your mobile and unlock the mobile and reset it with a new password.
- The IMEI number can usually be found on the sticker underneath the battery or by
typing *#06# into the phone keypad.
Hope this helps, please rate and leave a comment if the solution was helpful, thanks!
2answers
Unlocking Nokia phone?
Hi
you can reformat your unit to software with twister series rebooter gadgets to unlock the unit. thanks!
I need to unlock a nokia 7373 on virgin imei : 356291016084845
hi how r u?
i forget my security code
i need to unlock please help me
Nokia 7373
I bought Nokia 7373 on ebay, not unlocked, my mistake! So after a lot of searching I found [email protected], PIN and PUK numbers usually come into play if you enter something the phone doesn't like, so I suggest you email them they charge £3.99, they need to know IMEI code and provider model and make, seems to me you have those, then £3.99 credit card or paypal and they unlock. If they cannot do this they refund your money. I discovered Nokia 7373 needs BB5 cable, but it may be different for you. Good luck
1helpful
Nokia 7373 restricted code
You can not unlock these phones using codes from the net, you only have 3 attempts to enter the code... The only way to get the correct code is from your original network (Virgin)
You can also unlock the phone from most decent phone shops, it requires hardware to be connected to the phone, can not be done for free over the internet.
Unlock nokia 7373
ok try following steps:reboot your phone when they getting reboot press = green button(answer key) + 3 star key(*) but befor that make sure that your phone data will be lost above procudere may restore factory settings of your phone
My nokia 7373
Hi becky i can help you but the problem is if you have entered the wrong code more than 5 times then the only way too unlock it is by using flash lead and unlocking software and equipment witch would cost more than the phone new ok.
If you want your master code then i need your imei number its located on back if phone under the battery and looks like 1234/1234/`1234567 its 15 numbers long ok i need this as every phone has a different master code based on the imei number so if you want this code then let me know ok speak soon
Unlocking
Hi Tibor - YES 100%
To unlock the phone we can do it with a code from your carrier - i need the imei and the name of the carrier its locked to.
To change the language we can do it, but we need the physical phone.
The Whole process would be $65 + return shipping if you want to do it.
Many local repair shops may damage the phone - it is BB5 - hard to unlock, but we are pros
http://horizonwirelessonline.com
1helpful
5answers
Security code
security code on a nokia is 5 digits try 12345
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
