Question about Jabra Cell Phones
My son bought a Jabra BT2080 and tried to set it up on his PS3 and it's not working. It recognizes the device but the scanning fails
Posted by mateyovl on
Anonymous
    New Friend:
After having the device recognized by the PS3, just go all the way to the right where your friends are listed and select "Start Chat" and select voice chat (it is not necessary to invite anyone into a chat to do this). Go to the little Tool Box for "Chat Settings", then select "Audio Device Settings" and make sure the Jabra BT2080 is selected for Output and Input.
If anything, I found a video that shows you how's it done attached.
Posted on Feb 25, 2010
How do i connect my headset jabra bt2080 to my laptop hp 620?
I also have laptop hp 620 and the jabra bt2080 which are working through a driverless bluetooth usb dongle v2.0 (China) after installing jabra pc suite_2.5.6. It is under my experiment as at the moment only the mic is working when you start windows speech recognition program. i am trying to get it working as playback device to listen music instead of headphone through jack.
Jul 16, 2011 | Jabra BT2080 Bluetooth Headset
My Blackberry is asking for the numeric pass key #
Most Bluetooth headsets require a passcode to sync with the phone and to make sure that is the device you want to sync with. Each of these manufactueres usually have a default passcode to use. It is usually in the manual.
For your Jabra BT2080 Bluetooth model the default code is: 0000 (4-zeroes)
Here is the link to your manual: http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT2070/BT2080_UM_6909.pdf
May 12, 2011 | Jabra BT2080 Bluetooth Headset
Jabra BT2080 - been working well, charges and shows green charged light but bluetooth doesn't light up and unit shuts off.
This problem is mostly associated with the battery of your device. In some cases, the battery is most likely to have expended it's lifespan.
In this case, all you need to do is to change the battery. It is advised that you get a professional to change the battery for you as trying to do this yourself could lead to a damage in the device.
Apr 23, 2011 | Jabra BT2080 Bluetooth Headset
Can you sync a Jabra BT2080 to a Jabra A120?
Hi Bobby Smith1,
Im afraid that is not possible.
the reason is that the Jabra BT2080 is only ment to connect to a mobile device which is used for calls.
and the Jabra A120s is only ment to be plugged into a speaker device whilst connected to a mobile phone.
in fact both the Jabras work like a Normal headset, thus two are not able to be connected. only through a mobile device.
i hope this helps, good luck!
Mar 15, 2011 | Audio Players & Recorders
I need a pass code for a BT2080 Jabra headset
most blue tooth devices have a factory pin or passcode they are as folllows 0000,or1234,or 9999,or 1111.hope this helps
Feb 22, 2011 | Jabra BT2080 Bluetooth Headset
Cannot get my phone to recognize the device. need steps 1,2,3
Here is the link pages 4and5 (http://img9.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT2070/BT2080_UM_6909.pdf)
Feb 12, 2011 | Jabra BT2080 Bluetooth Headset
I forgot my password for my jabra 2080 want to see if there is a reset code to make a new one
You could try the bluetooth generic passwords (0000 and 1234), these usually work with most devices.
Feb 02, 2011 | Jabra BT2080 Bluetooth Headset
Cell Phones Logo
1,546 people viewed this question
Top Jabra Cell Phones Experts
Anthony Ward
Anthony Ward
Tom Chichester
SANTHOSH
Are you a Jabra Cell Phone Expert? Answer questions, earn points and help others
