Good day,
The capacitor will not show continuety. That is normal.
To test it, you must have an anolog vom meter, a digital meter will not work.
If you have an anolog meter (the type that has a needle that swings from left to right) set the ohms setting at it's highest position, at least RX1000. Higher would be better,
Check the meter by touching the probes together, They should swing the needle from left to right. Then..
This must be done quickly. Place one probe on each terminal of the capacitor. Then quickly reverse the probes. You should see a short, quick, jump of the meter.
If so, the capacitor is O.K. If nothing the capacitor is bad.
Thank you for using FixYa
