Sanyo SR-3620 Compact Refrigerator Logo
Posted on Jan 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Maytag model mtb1953ar refrigerator runs all the time and freezes everything in the refrigerator.
Anonymous
Level 3:
President:
  • Master 1,218 Answers
  • Posted on Jan 11, 2010
Anonymous
Master
Level 3:
President:
Answers
1218
Questions
Helped
276961
Points
3870
Good day,
Your machine is a pretty conventional design.
If it runs continuously then it would freeze the food.
You could try turning it to a warmer setting, but in all probability,
you will have to replace the cold control (the thermostat).
If you're going to do the work yourself, most decent sized appliance parts houses will stock that part.
Thank you for using FixYa
Maytag MFI2569VEM chills to the point that everything in the refrigerator section will freeze, regardless of the temperature setting on the front panel.
these tipe of units have an electronic board that controls basicly everything thats your problem you need to replace the electronic board. some times a temperature sensor wired to the elect. board fails but most of the time the board is the problem
I have a model MTB1956GE Maytag Fridge, Frezzer
Can you feel air moving or hear the fan running in the freezer section? You said the freezer section is freezing well, but is it freezing really hard?
Regards,Richard
Maytag Model MFF2557KES EVERYTHING FREEZES TOP AND BOTTOM COMPARTMENT
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
I have a Magic Chef compact refrigerator model MCBR270 that now runs constantly and freezes everything I put in it no matter what setting is used on the temperature control knob. What can I do to diagnose...
Well, this answer is 6 years late.
I have the same model MC frig - 14 years old. There is only two electrical components; the compressor and the thermostat. Since the compressor is running and freezing, the thermostat must be stuck on. You need to replace the thermostat. My thermostat is also bad. I can't find one. One of the numbers on the thermostat is LR62862. Another is PFN-110U 02D. May be time for a new frig.
I'm having trouble with Maytag model MF12067AEB refrigerator that started about 6 months ago. The vegetables/fruits are freezing in the bins....the repairman has been to my house 3 times....replacing the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Refrigerator is on lowest setting, but everything is still freezi
you need either a temperature control #66005516 or more probably a new auto damper # 61005989 they ar both in the back at the top of the fresh food section under the plastic slide control housing they are easy to replace be care ful and take your time disassembling and reassmbly will be much smoother.
go to apdepot.com and enter in the model number etc and you will se a blow up of the unit itself under controls.
Maytag Plus side by side (Model MSD2356AEA)not cooling in
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
hhkgjd
1helpful
Everything in my Maytag model MBB1952HEW refrigerator freezes. It is running pretty much non stop now
You will need to replace the control board, which controls the temperature in both compartments, refrigerator and freezer.
Top Sanyo Refrigerators Experts
NOEL
NOEL
john h
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
