This means that your call diverts are activated,from the moment you press the send key and until the system assigns a channel for your call, any incoming calls will be automatically directed to your voice mail....
to de activate this go to menu,>settings>call settings>call diverts
this includes option for activating/de activating calls to other phones
It means that you have set up that incoming calls will be diverted (to your voicemail usually) when your "line is engaged", ie when you talk with someone on the phone.
There are 3 diverts: divert on busy, on not available (switched off or out of range) and on no answer (when you don't answer after a certain period).
Depending on operator, they can be activated or deactivated individually, or all three at the same time. The latter option is bad in my opinion - who needs divert on busy? If the phone is busy, try again in a couple of minutes I say...
Anyway, this message is nothing to worry about.
whenever i try to make a call it comes up active incoming call divert ,I have turned off all diverts and it still comes up please help
sorry its a nokia C2
