My laptop burner has finally given up! It only reads cds and dvds but cannot burn anymore. Been in use for 3.5 years and I want to replace the dvd burner with a new one.
If your DVD burner is an old one then the Laser could be going out in which it is not powerful enough to burn Discs anymore but it can still read them. Can it read DVDs?
The more advanced the media is the more likely it can't read them in a older Player. DVDs would be hardest to burn or even read.
If this is the case the DVD burner must be replaced. They are cheap and I would recommend newegg.com. A typical DVD burner is $30.
It is a DVD ROM drive which stands for DVD Read Only Memory. In other words, this drive is meant to only PLAY DVDs and CDs but NOT save data to them.
To burn CDs you need a CD burner. Burners are of 3 types:
CD writer only burns and reads CDs.
Combo drive reads CDs and DVDs but only burns CDs.
Super drive burns and reads from CDs and DVDs.
As you go higher in functionality, the price also increases. Check your needs before you plan to buy one. Also compare prices of all the drives. Note: burn-able media costs are separate.
i think you,ve hit the nail-on-the-head.
The laser has to power up highrer to write a DVD, or ocassionally have a dual laser. 1 for read/write CD. And 1 For Read/Write DVD.
Certain cd roms, only use CD- media. it,s probably worth checking which media is supported by the drive.
Also check the drives aren,t conflicting, on the same ide channel, sometimes swapping channels, ide primary/secondary can help, or swiitching Master/Slave/cable select jumpers on the drives Themselves.
try isolating the problem by plugging an external cd/dvd drive via the USB. use this to burn CD/DVD if the process works, replace your laptop dvd drive.
Read on your optical drive. If it burns CD's it reads CD-RW. In order to burn DVD's it needs ro read DVD-RW. If it reads DVD-ROM it will only read DVD's not burn them.
A good external burner is Plextor. You can get one at Walmart, or you can check Ebay and find an internal to replace the one in your machine. They are fairly easy to replace, and you won't have a bulky external to carry around.
This is a common issue with NEC DVD burners, assuming that your NEC DVD burner cannot read and write DVDs anymore. I had a similar issue with my NEC DVD burner, which couldn't read and write CDs, but DVDs successfully. This is usually due to wear and tear of constant usage of the drive itself and sometimes mechanisms inside the DVD burner cease to work. While Windows Troubleshooting, uninstalling and re-installing the drive are suggestable, I am afraid the only option is a complete DVD burner replacement.
