Question about Ruud UBHC Air Conditioner
Heating unit blows warm air then turns to cold air
The heating unit will initially blow warm air, but then cool air starts blowing out. Could there be a problem with a coil? Can temporarily fix the problem by shuting off the unit for about 30 minutes and then turn it back on.
Posted by sgriner on
Mark Crowder
    New Friend:
One or both heat sequences. Check for coil voltage, then outlet side of both sequencers , if it not there, replace. If v is present when called for; check time delays for accuracy. Could be dropping if contact surfaces degrading.
Posted on Mar 13, 2019
Anonymous
    New Friend:
  • 14 Answers
It sounds like unit could be kicking out the low pressure switch or if it is a electric furnace it could be the sequincers
Posted on Jan 24, 2010
Amana Wall unit blows cold air before heating
The cold that you describe may be just unconditioned air? If you are certain you can hear the comp operating for a couple of minutes, and then the heat starts, I would guess it is a reversing valve issue if it's a heat pump and it probably is. Or the control board acting up. I've had a lot of issues with the boards in the Amanda PTAC units. I can't remember how to configure it, but if you Google "Amanda ptac configuration", there is a lot of info online. May try a reset method first. Hope this helps!
Mar 17, 2017 | Amana Heating & Cooling
Heater temp on high only bows luke warm air after driving. A/C works just fine.Plenty of cold air from it
heater blows cold air idle chrysler 300 Questions & Answers ...
www.fixya.com > Forum > Tags
Find solutions to your heater blows cold air idle chrysler 300 question. ... blow warmair for a few mins then back to luke warm. i replaced thermostat ... HEAT BLOWSCOLD AIR WHEN IDLING ONLY GETS HOT WHEN START DRIVING ... About 15 minutes after driving the diver side vents start blowing straight cold air but the ...
Heater only works when pressing the gas? - DoItYourself.com ...
www.doityourself.com/...repairs.../459521-heater-only-works-when-pres...
Nov 3, 2011 - When I press the gas, the air from the vents is nice and hot. .... So am Idriving a car with a ton of problems, or could the power steering ... Just anotherquestion, when warmed up does the engine temperature ... When the heater is on and I'm not pressing the gas pedal, luke warm air blows from the vents.
Heater blows cool air when stopped and warm air while ...
https://www.reddit.com/.../heater_blows_cool_air_when_stopped_...
RedditFeb 12, 2014 - Heater blows cool air when stopped and warm air while driving 2008 Kia Spectra (self. ... just fine but appears to blow cool air when I was stopped at a stoplight. ... My temp gauge would also be pegged high when at idle / low RPM. ...thermostat only blocks coolant going to the radiator, and the heater core, ...Missing: 300m ‎luke
Why is My Car AC Blowing Hot Air? - BlueDevil Products
gobdp.com/blog/car-ac-blowing-hot-air/
Jan 27, 2016 | 2000 Chrysler 300M
LG LP0711WNR blows cold air for a few minutes, then starts blowing warm air. It will start blowing cold air again if I wait several minutes. Or if I turn it off and wait a few minutes it will blow c
I just experienced this problem myself. What helped me was cleaning out the lint trap. My guess is that the until sucks in air through there, then conditions it. Blows the cold air out the top, and hot air out the tube. When it can't suck a decent amount of air in, the condenser can only condense so much of that limited amount of air. When it runs out, the unit just runs the fan until enough air has been condensed.
My lint trap was filthy, hadnt Bern cleaned in years. Soon as I popped it off, the unit started belching out cold air nonstop. Clean your lint traps! Don't make my mistake!
Jul 09, 2012 | LG LP0711WNR Portable Air Conditioner
I have a 2002 Volvo S60 air conditioning problem. Initially, the air conditioner will blow cool/cold air, but when I get in traffic and have to do a lot of stopping and starting the air turns warm. Have...
check to see if your cooling fans are working because when they dont work, your air will blow nice and cold when driving but will be hot air when stopped in traffic.
Jun 15, 2011 | 2002 Volvo S60
No heat jaguar 88 xj6 fan wont turn on cool air out the defrost vent
I have the similar problem with both my Jaguars, one is a 1988 Jaguar XJS, the other is a 1987 Jaguar XJ6, both blow COLD air out some vents while it blows warm air for heat. I heard it had something to do with the cold air blowing as a dehumidifier, I don't know if this is true, but it is really annoying to have both cold and warm air blowing when I need heat in these cold Canadian winters. If you find out please drop this website a note and let us know how you solved it. thanks.
Nov 12, 2009 | 1988 Jaguar XJ6
Blowing out warm air
Turn thermostat switch to 'cool' setting. It's a 'heat pump' and is in the heat mode.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Nov 05, 2009 | Coffee Makers & Espresso Machines
No heat air is blowing cold
First you have to identify what causes the problem.
To do this you have to:
1) When engine is cold check the level of coolant. If it is low fill it up.
2) Start engine and check if engine reaches regular temperature. If your engine is not heated enough it means your thermostat does not work properly and should be replaced.
3) If engine temperature is normal, then check the temperature of pipes that go to/from heater core. These pipes are located up the fire wall (easier access is from the passenger side). If pipe/pipes are cold (even engine is worm) it means you heater core is plugged and should be flushed. Keep in mind, flushing the whole cooling system is different from flushing heater core.
4) If pipe/pipes are hot/warm, turn off the fan, switch controller to the hot position, wait for 3-4 minutes and turn on the fan. Note if the cold air blows first or warm air blows first but it cools down in 5-10 seconds. If the air blows cold than it is most probably the problem with blend door or blend door actuator.
5) If air blows warm first and then cools down, then while running engine and remaining the transmission in PARKING position, press on the gas pedal until your engine reaches 3,000 RPM. Check if your heater blows warm/hot air. If it does, then your water pump does not work properly and should be replaced. If the air still cold, I would suggest to flush the heater core.
Oct 22, 2009 | 1998 Ford Taurus
Uotside unit blowing cool air but hot on the inside
It sounds like you have a unit called a heat pump. When a heat pump unit is in cooling mode the outside unit blows hot air and the inside unit blows cold air. If the outside unit is blowing cold then the indoor unit is most likely blowing room temperature or warm air. It sounds like the thermostat could be controlling incorrectly or you could have a failed reversing valve which is the device that switches the unit from heating to cooling mode.
May 31, 2009 | Ruud UBHC Air Conditioner
Ruud UBHC Air Conditioner Logo
437 people viewed this question
Top Ruud Heating & Cooling Experts
Dennis Boxerman
jdthefixer
Marvin
Marvin
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
