Exercise & Fitness Logo
Posted on Jan 11, 2010
I have a proform elliptical when the batteries died in the consel we replaced them now it does not come on.we made sure they were in correct and they are
Anonymous
Level 1:
New Friend:
  • Contributor 43 Answers
  • Posted on Jan 11, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
43
Questions
0
Helped
22237
Points
78
D size batterys, new batterys from package-not drawer... flat side of battery to spring...
What would cause the resistance to stop working on the console of my Proform 390 E elliptical?
How to Replace an Elliptical Resistance Motor
of course see if the cables is good, and test the batteries
or connector before and cleaned with electronic contacts cleaner-
test the terminal at motor for 9VDC APROX if there are the motor is faulty, use the DMM.
Blessing
[email protected]
cell+whatsApp: +50588611441
My Proform 6.0 ZE elliptical is draining new batteries within hours and humming. It makes LOUD popping and static sounds when using the AC plug in.
DEAR
AT FIRST YOU COUNT YOUR BAT AND MULTIPLY 1.5 THEN YOU USE A ADAPTER AC TO DC WITH SAME VOLTAGE LIKE 6 V OR 9V DC
you can countiue contact us with smart phone on wattsapp or telegram by :
+989195116738
Display on Proform 490 LE elliptical shows FF -- How do I fix it?
1) PLEASE replace batteries by new ones.
2) clean the batteries contacts with special spray contacts cleaner
3) retight the spring contacts batteries with a pliers for better contacts very important!
4) adjust the reed switch see the diagram attached.
God bless yu
1helpful
After replacing batteries on Proform PF800 console stays lit
Pull the batteries out let it reset itself while its doing that check all cable to make the connection are seated firmly then reinstall the batteries, unless the function pad is sending a phantom signal engaging the display to be on continuously,or by pure chance the upper electronics went hay wire
1helpful
2answers
I have an older proform elliptical and the battery cover cracked.
Go to FitnessRepairParts com and type in your exact model number in the search box at the top to view the parts list for that model. You may be able to find a cover there. Or you can contact support if you can't find your exact model number, they are very helpful
Have proform 850 elliptical, unit jerks at bottom of travel
This is caused by a loose crank arm. The key assembly is loose. (#32 on your parts list) The covers will need to be removed to access this. Be sure the crank arms are realigned against the frame when completing the repair. Good luck, Tim
Top Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
