Question about Visioneer OneTouch 7100 Flatbed Scanner
Does the Visioneer OneTouch 7100 work with Windows 7? Where can I find a driver?
Posted by alansueg on
Anonymous
    New Friend:
I scanned by cannon scanner (canoscan D646u ex).Suddently the error message appeared that Release the lock switch, detach the usb cable and reconnect.close the scanner driver. What can I do ?
Posted on Jan 11, 2010
1 Related Answer
Anonymous
SOURCE: Visioneer OneTouch 5820 USB for windows 7
ok guys here is the fix for vist and or windows 7 to make your scanners work
1. put your cd in the drive don't let it autorun
2. goto my computer then right click the driver that has your install disk in it
3. click open
4. then fine the drivers folder and open it
4. the file you see should be your driver for your scanner the number on this file should be the modle # of your scanner
5. right click that file then click run as adm. allow any and all pop up's
6. after the install is done restart your computer
7.after the computer reboots go back to my computer and open the driver that has you install disk and open it (do not do auto open) like for this file start32.exe and right click it then click run as adm. allow any and all pop up's (you may see something saying in any one of the steps that the driver or software u are trying to load dose not have a signature always click ok, allow, or indtall this sofe ware is old so it dose not have a signature)
8. after the install is done reboot your computer goto control panle and open it look for systems and open it goto device manager open it then look for your scanner it should not be hard to fine it's the one marked with the yellow flag
9. right that file then goto properties then click on it then goto update driver ( do not click driver update software in the same menu with properties) another menu will open up click on update driver it's just below the driver details box
10. now windows will update your driver when done restart your computer and y should be good to go
Posted on Jun 20, 2010
Window 7 driver of visioneer 9320
This model is discontinued from OEM. So, it will not work on Windows 7. For more information, please visit the following links:
http://support.visioneer.com/products/9320/default.asp
http://support.visioneer.com/KnowledgeBase/Articles/VIS1493%20-%20Updating%20Your%20Scanner%20Driver.asp?ScannerModel=DM3115&bit=32
Hope the above information is helpful.
Thanks & regards,
Scancare
Hi, I want to use my old visioneer onetouch 7100 usb scanner with win 7, but can't find a driver. can you please help? thank you!
In this instance it looks like this is not compatible with Windows 7. However, sometimes a windows XP driver can work absolutely fine... I would just suggest to give it a try!
http://support.visioneer.com/products/7100/downloads.asp
good luck!
2answers
Need a driver for Visioneer OneTouch 8700 Flatbed Scanner
The drivers for supported OS versions are available here: http://support.visioneer.com/products/8700/downloads.asp . The supported OS versions are: Windows XP SP 1 / 2000 Professional / Me / 98SE and the additional software that was bundled on the CD is not included.
If you have a different Microsoft OS, you can check the Microsoft compatibility center for either Vidat or Win7. A check of the Win7 compatibility Center http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx showed some Visioneer OneTouch scanners work with Win7. However, the 8700F is not in the list.
I hope this helps.
(Dual boot with XP or a virtual computer with an older valid OS version will work. The Win7 Pro and Ultimate let you use Virtual PC and XP mode to run an XP virtual computer for free.)
6helpful
3answers
Driver for vsioneer OneTouch 8900 for Windows 7
First install your regular drivers for your scanner and then turn it off.
http://support.visioneer.com/products/9420/downloads_1.asp
Download drivers for your scanner from the page above, don't mind it is not the same model - it will work. Also it will work with One touch 8700 Visioneer windows 7 x64 with the drivers for 8900 and 9420.
Next, install the driver, and then open Windows Explorer i locate files at:
C:\Windows\twain_32\VizScan\8xxx. Copy them all to:
C:\Program Files\Visioneer\OneTouch 4.0\9420 Driver
Next step is to tell your computer exactly what driver to use by right clicking on My Computer in Windows Explorer, then Properties, and then Device Manager. Now, turn on your scanner and it will appear on the list. Right click on it and select Properties. There click "Browse my computer for driver software" and then "Let me pick from a list of device drivers on my computer" and browse to: C:\Program Files\Visioneer\OneTouch 4.0\9420 Driver. Select OT_9420.inf and install it. Now u can use your scanner on Win7 and enjoy! Don't mind the different name! ;)
All the best to ya all
OneTouch 7100 Flatbed Scanner: Hello, I have a visioneer 7100USB scanner (from lo...
Try typing the model details into google ( or look on your manufacters website )
Alot of blogs find ways to bypass such things.
Cannot find driver for vista operating system, for visioneer 7100 scanner.
According to Visioneer themselves no Vista driver has been produced. "7100 TWAIN Driver Only included on the installation CD
Windows XP / 2000 / Me / 98SE
There is no updated driver available."
1helpful
I have a visioneer onetouch 8900 and my new computer has Windows 7 on it. Visioneer does not support it anymore, where can I get a driver patch to make it work?
.the Visioneer 9420 scanner program will run the 8900. You can run Visioneer 8900 in Windows 7, and Vista. uing thedriver for9420. Please type 'Can I run Vissioner 8900in vista?
you should see a web site for icrosoft forums that gives the steps involved to get your scanner to work in both Vista and Windows 7.0
Is there a driver available for the Visioneer 7100 usb?
maybe this will help.http://social.technet.microsoft.com/Forums/en-US/itprovistahardware/thread/f2d460e8-bb39-4576-86f6-4615fdb88049/
I need to connect Visioneer onetouch 7100 to windows Vista
There are no Vista drivers for this scanner
http://support.visioneer.com/products/7100/default.asp
1helpful
Help me install my visioneer one touch 7100usb scanner
Here is the VIsioneer download site for your model:
Download and install the driver. The instructions are indicated on this page also.
Open Questions:
Visioneer OneTouch 7100 Flatbed Scanner Logo
Top Visioneer Office Equipment & Supplies Experts
Ekse
scramblepad
scramblepad
Are you a Visioneer Office Equipment and Supply Expert? Answer questions, earn points and help others
