Question about Olympus Stylus 720 SW Digital Camera
720sw LCD screen died
I have a 3 yrs old 720sw and has seen some action. Yesterday, at the beach, the lcd screen stopped working. I can still point and shoot but I have to download pics to laptop to view (kinda like the olden days of 35mm, waiting for photos to process). Is there a simple way to reset/test if the LCD or is it time for a newer model?
  • Anonymous Jan 11, 2010
    It didn't get overly hot, hanging on my wrist most of the time. It would have been far hotter in our car on previous occasions.
  • Anonymous Jan 14, 2010
    It's been two days and when I turned the camera on today the lcd flicked on for several seconds and then went dead. It did it several times when I fired it up, but now the screen is black all the time. Any thoughts?
    Thanks
    Michael
Ty Price
    Brigadier General:
  • 11,967 Answers
Yesterday, at the beach, how hot did your camera get?
Posted on Jan 11, 2010
  • Ty Price Jan 14, 2010
    After reading up on your camera specs, it seems this was a rugged camera and should be able to stand up to quite a bit of abuse. At this point, if it were my camera, I would go to the support section of the Olympus web site and e-mail one of the techs and explain my problem. They may have a simple solution.
    One more thing I thought of...you say your camera is 3 years old. Is the rechargeable battery the original one with the camera? If so, it may be past its useful life and not delivering enough power to light up the screen. It may even appear fully charged and still only hold a fraction of what it used to hold.
Acer aspire 5738 screen fade
From your description, you may either have a bad cable to the LCD on your laptop or the LCD screen itself is going bad. I would guess a repair shop may charge $100-200 for the parts and labor, but you'll have to check your local area for price estimates.
Since your computer is nearly 3 years old, you may want to consider purchasing a new computer, especially since they start at $300-500 brand new.
May 19, 2017 | Computers & Internet
Olympus 850 sw digital camera 2 yrs old! Used all day perfectly fine turned back on screen blank, still takes photos, Still flashes, still beeps when press buttons just lcd screen is black likes its off?...
Hi
Either the LCD screen is cracked or defective in some other manner. It's possible the LCD works but just the backlight is out as well. Either way, the camera needs to be opened and the LCD checked out.
The Olympus "Tough" and "SW" cameras are FAR FROM being either "Tough" or "S"hock and "W"aterproof. I have seen dozens and dozens of them with cracked glass over the LCD and destroyed by water damage. Sounds like something got inside your camera or it was badly dropped.
Hope this helps.
Thomas Drayton
Owner, Darntoothysam.com
Affordable Digital Camera Repair
Sep 07, 2011 | Olympus ? 850 SW Digital Camera
About 3 yrs old. Picture is distorted for about 1/2 hour until tv warms up. Now has horizontal lines going through the picture and stays distorted on the right side of the screen.
This tv problems it is alway the board that call the T-CON decodering board it is dying.This T-CON decodering board sit in the middle at the bottom of the tv LCD screen panel.This T-CON decodering board decodes all the tv picture dots pixels before it go into the tv LCD screen panel itself.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish T-CON decodering board for the replacement.
May 09, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Well !! my computer is 2 yrs old and there is a shade difference in the screen,a vertical line has appeared and the upper part of the screen has faded,the mouse is also not working on the upper part,it is...
You don't. From what i can tell, your screen is little more than expensive garbage at this point; your LCD is done. To verify this, plug the screen into a different computer. If your screen does the same thing, throw it out. But if you REALLY want it fixed instead of buying a new one, try replacing the LCD.
Feb 18, 2011 | LG L1915S 19" LCD Monitor
No picture
By blank, do you mean a white screen? If you have a white screen and sound, then the LCD panel has failed, either the internal panel or the T-Con board driving it. Only an expect can tell you if it can be fixed. Lots of these sets die within 3 yrs. The cheap brands faster than the better brands.
Apr 30, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Vertical colour lines on whole screen
The problem is that the panel has failed. Apparently this is a common problem with LCD TV's between 18 mths and 3 yrs old. If it survives over 3 yrs it is likely to last for a few years longer. The cost of replacing the panel is more than a replacement TV!
May 25, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Benq 19' LCD Screen 3 yrs old- no signal detected on brand new PC
Have a look at the back of your computer.
See if there is more than 1 video port.
If there are 2 ports try plugging the monitor into the other port....
Sometimes motherboards have internal video cards, in this case the video port is in among the USB ports, sound and mike sockets etc.
Look for a video port away from all those other things.
Apr 26, 2009 | BenQ FP71E 17" LCD Monitor
I cannot get the LCD view screen to work ?
There should be a menu button on the camera. if there is, go into the settings and turn the LCD Screen back on. (Actually if you press the menu button on the camera, you should see the menu on the LCD screen.) There is an option to turn off the screen to save battery life.
Dec 17, 2008 | Nikon D70s Digital Camera
Poor screen quality
re install your dell video card driver
Oct 19, 2008 | Acer AL1916W 19" LCD Monitor
LCD screen goes black when opened
the flex wire of the lcd monitor is already cut ...go the service center for replacement of the flex wire...or to the other service center for fixing the flex wire...it is to difficult to fix the wire if you are not a technician cause that wire is like a strand of hair...
Sep 07, 2007 | Panasonic PV-GS19 Mini DV Digital...
Olympus Stylus 720 SW Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jax Planet
Jax Planet
Are you an Olympus Camera Expert? Answer questions, earn points and help others
