Sharp Notevision PG-M20X Multimedia Projector Logo
Posted on Jan 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
There is a blinking green lamp light and the lamp will not fire up. it keeps shutting off
Anonymous
Level 2:
Scholar:
  • Expert 150 Answers
  • Posted on Jan 17, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
150
Questions
0
Helped
46177
Points
248
Time to replace the lamp, sounds like it has expired. Lamp light is probably about to go red too when it's really bad! :
Good Luck!
Have a mitsub. WD-73734 working fine this morning with white and black dots - replaced the chip and now the tv won't turn on, green light blinks raptly then the lamp light starts to blinks red/orange
Somehow--the lamp is not firing. Before you go get another bulb--check ALL of your work, and make SURE no connectors to the ballast have been left off or pinched somehow. It is easy to do this. Also, make sure the lamp door switch is making proper contact with the tab on the lamp door. You have already fixed a real problem with this set--do NOT give up so easily now!! ALso--make sure all fans are running. If ANY do not run--it WILL shut down. ANd make sure the color wheel connector has not come loose or been damaged somehow (this will be between the engine and the lamp area--likely have a "hump " raised in the light tunnel betwen the lamp and the engine--this is where the CW is). Even IF the ballast died (NOT likely at all), you can find one on ebay for under 100---and this set IS WORTH the repair. You will NOT be satisfied with some crappy flat-panel as a replacement.
3helpful
Hi, My hc1500 Is having a problem. When I turn it on it makes a clicking sound. Then the Lamp fails to light. The Light is green and the status is green, but soon after the projector shuts off the power...
The clicking sound is the high voltage power supply trying to
ignite the gas in the lamp. The lamp is not firing and coming on.
Check the bulb/ lamp life. Possible the lamp has exceeded its
useful life and may need to be replaced.
2helpful
3answers
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
2helpful
The green light blink for a while and then shuts off and the lamp light blinks once red???
The green blinking lamp means that the TV is getting ready to start the lamp, and then one red LAMP blink means the lamp will not start. You may need a new lamp (Part TYLA1001.)
If a tech confirms this, and you can source the part, you can find TYLA1001 installation instructions here to save a few dollars, and PT-52LCX66 lamp timer reset steps here.
I hope that helps.
2answers
I turn tv on...green light comes on but i get no picture or audio....then light indicator blinks red
Hello!
Lamp or ballast(if lamp has been replaced) is bad.
Explanation: green comes on: system works, waiting for light to shine into light engine: no light is coming out of lamp, system shuts down, then you see red! how to determine: pull the lamp out of the unit's compartment. Inspect lamp: bloated stem? shuttered? reflector is not shiny? Chuck it!
Lamp looks good or just been replaced: try ballast. Close lamp compartment without lamp itself. Make sure, door is shut, as well. Turn unit on and listen close to lamp compartment: good ballast will make a buzzing noise, then stop. You've got "red'! No buzzing: ballast quit. Needs major repair! Lamp must be good, for sure, to get to the last part of diagnostics. Conclusion: more, than 2000 hours of usage: replace lamp first!
Good luck,
Alex.
Tv shuts off and green light blinks 5 times and repeats 5 blinks.
Please buy new Lamp for KDF-55WF655 from Sony Accessories Store with following part number..
" A1085447A " LAMP BLOCK ASSY XL-2200U
(type model number in search box and click)
Always buy Sony original lamp for safety of your TV.
New Bulb Doesn't Light
color wheel or light engine,call for service and save your money.
1helpful
4answers
Tv cuts off and green light flashes
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Bulb doesn't light
yip, sounds very familiar
steve, does the pj lamp try to fire up.
does it briefly light up then shut off
these are the typ. symptoms of an expired lamp
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
