Question about ASUS K8V-VM (K8V-VM GREEN) Motherboard
I m having asus k8v-vm bt no space for sound card
I m having asus k8v-vm motherboard wid amd sempron 2800+ i hav nvidia geforce 6200 le and a capture dere r 3 ports in motherboard n i wanna install a sound card but hav no space help will be appreciated
Posted by shourjacoold on
  • Anonymous May 11, 2010
    You have a PCI-E slot and two PCI. All slots are being used? If you're using a PCI-E card and a PCI capture card, you should have one more PCI slot available.
Anonymous
    President:
  • 2,351 Answers
The Asus K8V-VM motherboard has an intergrated audio chip on the motherboard, Realtek ALC660. You need to enable it in the bios. If you do not have you're manual down load it from Asus; http://www.asus.com/Search.aspx?SearchKey=K8V-VM You'll also need Adobe reader installed to view the manual. Enter the bios menu. Open Advanced. See the top of page
2-21 in the manual. Set, High definition Audio to [Auto] Save and exit the bios. Also check out page 1-19. You can install the driver software from the Asus CD or download it from the Asus link provided above.
Realtek Audio Driver V5.10.0.5211 for Windows 2000/XP/XP 64bit. (WHQL)
Cheers'
Mike
Posted on Jan 10, 2010
I use an ASUS K8V-VM motherboard with AMD sepmron 2800+ processor. os is XP sp3. which vga driver do i need to install.
video card is better but here is motherboard download area driver http://support.asus.com/download.aspx?SLanguage=en&m=K8V-VM&os=17
Mar 09, 2013 | ASUS K8V-VM Motherboard
I use an ASUS K8V-VM motherboard with AMD sepmron 2800+ processor. os is XP sp3 (wish to enhance to windows 7). I tried to install Galaxy 8400GS graphic card but when I start the system with the card, the...
You need the latest display driver for your graphics card.
Click here to download the drivers off the Nvidia website.
Enter the information in the fields as shown below;
Product Type: Geforce
Product Series: Geforce 8 Series
Product: 8400GS
Operating System: Select the operating system you are using. XP or 7 whichever it is.
Language: Choose your Language, English
Then click search and download and install the driver.
This should solve your problem!
Do do recommend sticking with XP as your current computer system will find it difficult to run Windows 7.
All the Best!
damnor01
Jan 19, 2011 | ASUS K8V-VM Motherboard
Lost my motherboard driver disk of asus k8v-vm, where i can downloard it
go= http://support.asus.com/download/download.aspx?SLanguage=en-us
go download>select>mother board>2nd select socket 754>3rd k8v vm and search and download
Name ASUS K8V-VM Description VIA K8M890, VIA VT8237A, DDR RAM, Micro ATX, Graphics card, Sound card, Network card Form factor Micro ATX CPU Type AMD Ahtlon 64/Sempron Number of CPUs Single Socket Socket 754 Front side bus 800 MHz MHz Chipset VIA K8M890, VIA VT8237A Memory type DDR RAM Number of DIMM-Slots 2 Number of RIMM-Slots 0 Max memory 2048 MB Memory speed DDR400, DDR333, DDR266 Serial Attached SCSI (SAS) No Serial ATA (SATA) Yes Serial ATA ports 2 Serial ATA 2 (SATA II) No Serial ATA 2 (SATA II) ports None IDE Ports 2 IDE Speed 33/66/100/133 MB/sec MB/sec Built in SCSI controller No Built in RAID controller Yes Built in graphics card Yes Built in sound card Yes Built in network card Yes Multiple GPU support No Crossfire support No SLI support No RoHS Compliant No AGP interface No AGP-slots 1 PCI-e (PCI-express) Yes PCI-e slots 2 PCI-e type 16x/1x PCI slots 2 PCI-X No CNR-slot 0 AMR-slot 0 eSATA No Bluetooth No WiFi No FireWire (IEEE1394) No Number of FireWire ports 0 USB type USB 2.0 Number of USB-ports 4 Number of parallel ports 1 Number of serial ports 1 RJ-45 (Ethernet) 1 PS/2 Keyboard 1 PS/2 Mouse 1 Line-out 1 Line-in 1 Microphone Yes Bios 4 Mb Flash ROM, AMI BIOS, (TCAV), PnP, DMI2.0, WfM2.0, SM BIOS 2.3, PXE Boot BIOS Miscellaneous Audio:- Realtek ALC660 6-Channel Codec, LAN:- Realtek RTL8201CL 10/100M LAN PHY
Nov 22, 2010 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
INSTALATION RAID
ASUS M3N78-VM Downloads
Click (+) "Manuals"
Cherchez "Version F4425" en francais
Click "Global"
Mar 11, 2010 | ASUS M3N78-VM nVidia GeForce 8200 AM2+/AM2...
COMMENT INSTALLER LES DISQUES DURS EN RAID
Salut ami !
STP suis cet adresse ci-dessous:
Choisis le manuel en francais et telecharge! Tu auras tout ce qu'il te faut!
Bon, n'oublie pas de nous evaluer! merci et bonne chance!
ASUS M3N78-VM motherboard Problemes
Good Motherboard...BTW... Reset BIOS to Factory defaults. Make sure you have the latest BIOS as well. Then you need to eliminate the other devices. Try running just on the On-Board Video...see if crashes. Run w 2 Gig Ram...same same... and of course the processor which may be impossible. Once you know it is MB or CPU... you make a choice which to buy or test. MB first... you can always return with less stress.
Dec 31, 2009 | ASUS M3N78-VM nVidia GeForce 8200 AM2+/AM2...
The best sistem for k8v-mx
Supports AMD Socket 754 Athlon 64/ Sempron processors, here is a list of processors supported by the motherboard >>>>
http://www.cpu-upgrade.com/mb-ASUS/K8V-MX.html
As for the graphics, the board supports PCI Express graphics cards, its up to you which card to buy, you can either purchase Nvidia Geforce 9 series or ATI Radeon HD series.
Regards.
Aug 01, 2009 | ASUS K8V-MX Motherboard
Upgrade P5RD1-VM motherboard to the gaming PC
Your pc is not for gaming right now because you are using Intel Pentuim 4 Mother board and CPU. Amd Athlon is best for gaming. I have a AMD Athlon 4200+ X2 with 4gb Ram and Nvidia 6800 256mb OC. to upgrade your computer to a gaming pc. you will need to switch your motherboard and cpu for best performance on games. in order to do that, you might need a different case for your new motherboard. because the one you have might not be right for the AMD Athlon motherboard unless you have a custom made computer. other than that everything is set for you. if you have less than 1gb ram you might want to add more. because the games they are coming with right now is 1gb minimum or required.
i hope that answers your question.
Thank You
Dec 08, 2007 | ASUS P5RD1-VM Motherboard
ASUS K8V-VM (K8V-VM GREEN) Motherboard Logo
299 people viewed this question
Top ASUS Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Roy May
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
