Hi, My Samtron Monitor has stopped displaying. The power LED blinks green at intervals of one second. When I remove the signal cable, the monitor does not display the 'No Signal' message. Please help
Your power supply is probably bad. open the case with it unpugged and look for leaking or crowned capacitors. most electronic repair shops can replace them for you
solution 1 please replace the horizontal output transistor in near to line output
solution 2 in case you changed the horizontal output when the problem not solved follow this.
monitor line output transformer burned replace them its kept on monitor from mother board to connect thru picture tube. very carefully to change the part because its have a storings voltage capacity in heavy.
solution 3 check the signal cable
Did you check the adjustment setting on the brightness and contrast?
These two setting can be moved and stop the CRT from displaying,
Please move these two setting to MAX and see is there any image on the display.
connect another cable as follows 1-red 2-green 3-blue 4-gnd 5-gnd 6-red gnd 7-green gnd 8-blue gnd 9-+5v from display card 10-stand by 11-synchronus ground 12-sda 13-hsync 14-vsync 15-scl
the numbers of pin are given under pin
1.poewr LED blinking or not.if in case LED blinks one time. problem in LOT .Cheak horzontal Transistor also.
1a) power out put voltages
2.drypoints in neck board.
3.cheak display cable.
The problem im facing is, im using a Samsung samtrong 56V monitor, there is horizontal line appearing in the both ends of the monitor screen which gives a mirroring effect. ( for ex: if ya move the cursor on that it will show multiples of cursors displayed in that line only.)
Please suggest me a method to solve this issue. are there any patch avail for this if so please send a link to download.
