Buck Dodge Ram 1500 2002 Car Radio/stereo Wire Harness Plug Logo
Posted on Jan 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
P 0700 code on my 2002 ram pickup? cannot find what this means on the web...
Anonymous
Level 3:
Brigadier General:
  • Master 5,158 Answers
  • Posted on Jan 11, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
5158
Questions
5
Helped
2065858
Points
15105
That code is a transmission fault... the quick fix appears to be to check the transmission fluid level and top it up (if needed)
2answers
I get code p0700 on 2004 dodge ram 1500 4.7 lt.
transmission system malfunction can be a few things the following links give some examples of different problems associated with p0700 code but more than likely if their is a noticeable problem than may have to have it diagnosed by a transmission shop
P0700 Transmission Control System Malfunction P0700 Dogge Ram Yahoo Video Search Results 2005 Dodge Ram 1500 transmission codes p0700 p0841 Transmission Automatic...
2002 dodge ram 1500 metering oil pump stepping motor circuit malfunction what is this and where is it located
Is there a code P0 something a DTC - diagnostic trouble code . Need to know more then metering oil pump stepper motor circuit malfunction
Key is stuck in ignition receiving no electricity
You are not the only one:
Key stuck in ignition, wont start, dodge ram pickup - Fixya
www.fixya.com/.../t14560159-key_stuck_in_ignition_wont_start_dodge
Oct 6, 2012 - key stuck in ignition, wont start, dodge ram pickup - Dodge Ram 1500question. ... 631 Answers. SOURCE: 1999 Dodge Ram 1500 Pickup error code p0171. This code means ... Jun 28, 2011 ' 1987 Dodge Ram 50 · 1 Answer .
Showing an 0700 code on my Dodge Ram.What does this code mean?
Transmission malfunction. This is generic. Get a better code reader and see what the codes are. Like P0733. 3rd gear ratio.
2answers
What is the code p 0700
No one can or should be telling you to replace
anything on any vehicle
Only knowledgeable people with proper reference material,
should even work on a car
Have it properly diagnosed
Ask around before you go to just any shop,
assuming you don't have one you used for
decades
That is a transmission code-- so stop using it
Any time you get any trans issues,all you need is a few
miles & you can ruin the trans in a heart beat
Code 0700 with 1391 stand to what
P0700 its a transmission codefrom what i understand while the 1391 is a crank postion sensor. the P0700 comes up when the neutral safety switch starts to fail, but the crank postion sensor...to get that error code, means you timing could be off..have you replaced a timing belt lately, if so, it might be a couple of teeth out, that might do it. i would check the sensor too though
1helpful
I want to know what trouble code P0700 means in a chrysler town and country 1998, and how do I reset the check engine light?
0700 is a "transmission control system malfunction". The entire 0700 series of codes deals with transmission trouble codes in more detail so the 0700 won't tell you much unless one or more of the other codes also were set.
2answers
I have a diagnostic code of p0700 and p1684 coming up for my 2002 dodge neon...anyone know what that means??
Hey, Code 0700-Transmission Control System (Malfunction Indicator Light Request)
Code 1684 -Battery disconnected during last 50 starts
1helpful
TCM codes
I'm having the same problems actually. Mine started with the transmission line popping off and spilling all of my fluid on the highway. Fun times and long story heh...anyhow, I believe that there is a special code reader for the p-0700 issues.
Does your car make a high pitched "eeeeeeeeeeeeeeeeeeeeeeeeeee" sound when you turn your key on, without the engine started?
Top Buck Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Steve Sweetleaf
Steve Sweetleaf
Are you a Buck Car Audio and Video Expert? Answer questions, earn points and help others
