Question about Rolex Watches
My wifes recently repaired Rolex loses about an
My wifes recently repaired Rolex (certified Rolex repair) loses about an hour per night.
Should she wind it until the crown stops?
Posted by sstevenson on
Anonymous
    Scholar:
  • 98 Answers
Is it an automatic self wind or wind up? An automatic watch has a weight that winds the main spring and if you wind it by the crown it will not stop. If its one that you wind by hand then the watch should be wound daily at the same time...like right before bed or when she wakes up. Wind gently until it stops. That costly repair should come with a warranty so if she consistently winds daily and still loses time you need to send it back!
If the watch is an automatic then she can gently hold the watch in her hand and rock it back and forth a good 20 times or so and that will give it a good winding! This is a common issue we see at our watch repair business. Some people do not move enough during the day to keep an automatic movement wound. If thats the case then there is nothing ong with the repair, just make sure it gets a good daily wind! :-)
Posted on Jan 10, 2010
Where is sell the bezel of seko kinetic SQ 50?
The bezel is available through any certified Seiko dealer, though I would suggest using one with a Certified Master Horologist on staff.
Thanks for rating! Expert watch repair for Rolex Breitling Tag Heuer Movado
Jun 23, 2014 | Seiko Kinetic watch
My three-year old (real) Rolex Oyster Perpetual Lady Date Just started losing time after just six months. It would stop and start intemittently and lose a few minutes every hour. Winding did no good. I...
It seems to me that the company servicing your timepiece (Rolex or otherwise) must have missed something or did not properly service your timepiece.
You are correct that your watch should not require service every ten months. After servicing, your Rolex, like most all automatics, should run properly for 3-5 years depending on environmental conditions. Our Rolex service offers a one year warranty, and if any issues present within that time, the service is free.
I would recommend using a company that has a full time Certified Master Horologist on staff to service your timepiece that offers a warranty on their work. Thanks for the rating, and we are happy to help you and service your Rolex.
http://www.watchandpen.com/id76.html
Oct 22, 2013 | Rolex Oyster Perpetual Lady Datejust...
Rolex Yatchmaster 2 second hand is not moving. Please help
Hi John,
Your Yachtmaster likely has one of three problems:
1) the hand loose on the pinion, or
2) the movement needs to be serviced
3) there is an issue with the button/gear for that function within the movement.
Automatic watches must be serviced every 3-5 years as the oils dry out and dust and debris in combination with the dried oils create excessive wear on the parts within the movement. As one must change oil in a fine automobile, it is the same with a Rolex.
We use the same processes as Rolex and are able to attain discontinued parts Rolex no longer supplies.
My suggestion is to use a Certified Master Horologist for your repair. We can certainly assist you with your repair at a much better price than Rolex. Thanks for the rating!
Sep 14, 2013 | Rolex Watches
Second hand goes backwards
I would recommend servicing your timepiece. Analyzing the movement with a timing machine or a physical examination of the movement is the only way to repair this issue. You may find a local Certified Master Horologist, or feel free to send it to our service center, we would be happy to help you!
Dec 22, 2012 | Rolex Lady Oyster Perpetual Watches...
I dropped my rolex
Its time for a service.
Take it to any Rolex re-seller that offers repair or to any good timepiece service center. If its a vintage piece i would recommend sending it to Rolex, paying the extra cost to receive the watch with full Rolex repair documents and service history. The Rolex web site has information on this. Also this company does a fine job on Rolex repair. https://www.bobswatches.com/rolex-repair-service
Jul 02, 2012 | Rolex Watches
My rolex watch stops while i am sleeping
Your Rolex is automatic?
This means it "recharges" while moving it. If you remove from your arm before going to sleep, then it does not "recharge".
But this is something your Rolex should not do it can by default hold the charge for more than one night.
A good watch repair service can handle this issue.
Aug 23, 2011 | Watches
My watch just stop working,that is the timing just stop working,so what can i do in respect to this and my watch model is( winner rolex ad day tona 1992 24)pls i need an urgent respond.looking forward for...
Unfortunately, for authentic Rolex watches you usually have to get the repairs done by an authorized Rolex dealer. Call your locally-owned high-end jeweler or go online (Google: Rolex Repair) to find an online repair resource. Sorry I couldn't help you!
May 03, 2011 | Rolex Daytona 116520 Wrist Watch
Want to know if my rolex is fake it states winner rolex addaytona 1992 24 on the back and rolex oyster perpetual superlative chronometer officially certified cosmograph on the front has three dials stating...
Sorry to say it's a reproduciton..and not a very accurate one..
The three front dials should not reference any days hour dates etc..
There should be nothing engraved on the back
The "second hand" is a sweep timer hand on the original.. it should be stationary at the noon position unless activated.
Probably a good looking watch.. but it's not a Rolex.
Best of luck
Jan 20, 2011 | Rolex Daytona 116520 Wrist Watch
I have a presidental perpetual that quits during the night. when I put in on in the morning it works fine. How long should it run when dormant
It sounds like your Rolex isnt retaining its power.If worn for 8 hours a Rolex in good condition will hold power for 36 hours.
Rolex watches need regular servicing every 4-5 years so it may be due a service,the mainspring may be broken or the automatic windind may have a fault.
You need an expert Rolex watchmaker to advise you try www.rolexrepairs.co.uk they offer a free estimate and repairs are returned in 2-3 weeks depending on the work.
Aug 15, 2010 | Rolex Day-Date President 118238 Wristwatch
I can not open the back cover of my Rolex Submariner, I hear something rattling inside.
If the watch is working okay, and it is a self-winding model (i.e. it doesnt not have a battery which relatively few Rolexs do) then the noise you probably can hear is the self-winding mechanism.
Rolex backs are very, very difficult to remove and watch repairers have special tools to do so. As a Rolex is an offically certified chronometer, and therefore has an incrediby accurate and complex mechanism, the backs are deliberatly designed to be difficult to remove by just anybody.
Oct 01, 2009 | Rolex Daytona 116520 Wrist Watch
Watches Logo
735 people viewed this question
Top Rolex Watches Experts
Bruce Robin
Janelle Schoonover
Janelle Schoonover
Are you a Rolex Watch Expert? Answer questions, earn points and help others
