Question about Spectroniq PLTV3250 32 in. LCD TV
Changed power supply on my spectroniq pltv 3250. it turned on,but now the picture comes on then leaves. you can hear the tv
Posted by erivera178 on
Bud Martin
  • 11,361 Answers
Posted on May 30, 2010
Have Protron PLTV-3250 TV and I was told the power supply board was bad. All indications concluded this was the problem. Replaced the power supply board (FSP194-3F01 power supply) and turned the TV on. ...
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 25, 2017 | Spectroniq PLTV3250 32 in. LCD TV
Just bought a used Protron PLTV-3250. No owners manual or remote. Could i find them? Do i need them? Thanks a million.....Pam
It is the same as Spectroniq 3250: Manual
http://www.retrevo.com/support/SpectronIQ-PLTV-3250-TVs-manual/id/926dj283/t/2/
Original remote is hard to come by, try EBAY, without orignal remote you may nat be able to access all the on screen setup functions. Watch out for the power supply module to go out on this TV.
http://s807.photobucket.com/albums/yy352/budm/Protron%20PLTV%203250/
Sep 30, 2010 | Protron PLTV3250 32 in. LCD Television
Was watching the televisions and it just went out. Unplugging it didn't reset it and the power cord is in pristine condition. Is the problem fixible?
Power supply failure in this Spectroniq/Protron PLTV-3250 is very common. That will be the first place to check.
Check the power supply; look for bad caps with leaking/bulging tops, check to see if you have standby +5vdc at the power supply connector, the front red indicator will not be on if you do not have this +5vdc standby voltage due to shorted out Q7 and ZD4.
Power supply: http://www.google.com/products?rlz=1T4GGIH_enUS282US283&q=pltv+3250+power+supply&um=1&ie=UTF-8&ei=9lIDTL7XO4fcM7HA-Ds&sa=X&oi=product_result_group&ct=title&resnum=1&ved=0CCgQrQQwAA
Aug 23, 2010 | Spectroniq PLTV3250 32 in. LCD TV
It won't turn on
Apr 29, 2010 | Spectroniq PLTV3250 32 in. LCD TV
My Spectroniq PLTV 3250 blacked out & no longer works. The only
Ur power supply board is dead.U have no electronics or machanicals skills at all,is that correct?Take it to the tv shop,it should cost u half of the price of the new tv to repair it.
Apr 28, 2010 | Spectroniq Protron PLTV-32 32 in. Plasma...
PLTV 3250 no power
First make sure it does have at least red indicator on the front panel, if not, the standby +5vdc is not working, common problem with this monitor is dead power supply due to bad caps, shorted transistor and Zener Diode in the standby power supply.
Power supply; http://www.google.com/products?rlz=1T4GGIH_enUS282US283&q=pltv+3250+power+supply&um=1&ie=UTF-8&ei=hdgBTL6MJaKMNZLC1Ts&sa=X&oi=product_result_group&ct=title&resnum=1&ved=0CCQQrQQwAA
Apr 26, 2010 | Spectroniq PLTV3250 32 in. LCD TV
The power is down it wont start,spectroniq pltv 3250
Look at the power supply first; look for burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc.
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=pltv-3250
Please post back what you find
Dec 17, 2009 | Spectroniq PLTV3250 32 in. LCD TV
Spectroniq PLTV-3250 turned off will not turn on?
Nov 22, 2009 | Spectroniq PLTV-42HW68 42 in. LCD TV
Spectroniq PLTV3250 32 in. LCD TV Logo
769 people viewed this question
Top Spectroniq Televison & Video Experts
Jayesh Panchal
Jayesh Panchal
ray gallant
Are you a Spectroniq Televison and Video Expert? Answer questions, earn points and help others
