Question about Watches
Resize DKNY 1035 Wrist Watch band
''Remove links'' to resize DKNY 1035 Wrist Watch band.
Posted by ulbnvs2 on
Anonymous
    Scholar:
  • 98 Answers
Could be a number of different ways. Some newer watches have multiple clasps that make it easier for you to adjust it yourself. Check the bottom of the band for extra clasps.
Without seeing the watch I have no idea what type of links you have. I suggest taking it to a reputable watch repair shop and have them adjust it for you! It will save you the frustration of having to search for a small screw or pin if it should fall on the floor!
Posted on Jan 10, 2010
Where can i buy a replacement wrist band for my dkny watch ny4886?
Fixya is unable to suggest sources of watch bands.
Mar 28, 2018 | DKNY Watches
How do you remove links from my watch band DKNY?
Instructions
    • 1 Determine the amount of links that need to be removed for the watch to fit on your arm correctly.
    • 2 Find the tiny holes on each link. Most DKNY link wristwatches, such as the 3107 model, have holes at the links near the clasp.
    • 3 Using the screwdriver, gently push the pin holding the link bar on the first link you want to remove. The link bar should come out on the other side.
    • 4 Take the pliers and completely remove the link bar from the band. The link band will still be attached to the clasp. Remove the link with the pliers. Repeat Steps 1 through 4 for each additional link you want to remove.
    • 5 Gather the watch band and and bring the two sides back together. Join the link bar and the clasp together and, using the screwdriver, press the link bar back into the hole completely.
How to Take the Links off DKNY Watch eHow
Aug 27, 2014 | Watches
How to remove watchband on timex atlantis 100
On this link you can see how to resize and remove the watch band.
You need some tools.
Resize your Watch Band and Remove Links with Basic Tools
Jul 21, 2014 | Timex Atlantis 100 77517 Wrist Watch
I have a dkny watch that i need to adjust the band on...it does have arrows and what appears to be small screws.....
it doesn't have arrows because you have to use small screw drivers to loosen it. so you can adjust it. You can buy it on any hardware store. i hope i had been helped you.
Jul 24, 2011 | DKNY 1035 Wrist Watch
Shorten the length of a Kenneth Cole "New York" watch band
With the watch on your wrist, check to see how many links need to be removed from your watch. Your watch should fit comfortably on your wrist. Remove the extra links with your paper clip or push pin.To remove the links from your watch, press on the small pins with your tool that are holding the links in place. The watch band should now separate allowing the pin to become free, and you can now remove the pins first and then the links one at a time until you have removed the desired amount of links. Reattach the watch band when you are done removing the links. To reattach the watch band to your watch, simply fit the end links into each other. To complete the resizing, use your push pin to re-insert a joining pin.
Jan 19, 2011 | Watches
Hi. Can You replace a Crystal for DKNY ladys watch model NY-4609 Thank You.
It is probably replaceable. Try to locate a watch repair shop or and jeweler who repairs watches. If they don't have one, then contact DKNY directly.
Jan 13, 2011 | DKNY 1035 Wrist Watch
How do you remove the links form the DKNY 4351ladies watch?
there are pins in the watch the pins have one large end and one small end you want to push the small side into the watch, make sure the pin can come out the other side you can use a thumb tack usually.
Aug 04, 2010 | DKNY 1009 Wrist Watch
Watch band resizing
This band requires a pair of band pliers to pull out a U shaped tab that connect the two links. Sometimes you can get a small screw driver in to start the tab coming out and pull it the rest of the way out with a pair of pliers. The tab is located in the middle. You'll note that, if you look at the side of the band, there are three layers of metal. The tab is in the middle and slides out. If you look at the inside of the band, the side that would be on your wrist, you will see the slot that the watch plier would fit into to start sliding the tab out.
* I do not recommend this repair for the layperson. I suggest seeing a watch maker/technician.
Jun 27, 2009 | Lucien Piccard 26024 Wrist Watch
Watch band sizing
OK, I make an attempt:
I saw on other pictures on the web that the links have small holes at the side. There should be some links with arrows r another marking. These are usually the links that can be removed to shorten the strap.
If there is a small arrow on the link, it means that you can push out the pin inside the hole in the direction of the arrow. Then the link can be detached.
You can push it out with a blunt sewing needle (break off the tip).
Remove links on both sides of the watch when resizing it.
Hope that helps.
Critter
Dec 26, 2008 | DKNY 1009 Wrist Watch
Wrist Band Resizing
I did find a solution. I used a push pin tack to push the pins out. Not easy but it did work.
Jun 16, 2007 | Field and Stream F112GUBS Wrist Watch
Watches Logo
1,128 people viewed this question
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
