Question about Casio G Shock Tough Solar Digital Sports #G2800B1V Watch for Men
Casio G Shock G2800 keeps going blank and resetting itself!
It resets itself to 00:00 Yr2000, and is therefore very unreliable. Also, when it starts working normally, every so often the RECOVER caption appears and the beeps stop! Does it need a new battery?
Arturs Kalnins
  • 2,338 Answers
You have to change the battery. After that your watch will be back to normal.
Rate me, plz.
Posted on Jan 10, 2010
Testimonial: "Thank you"
How to reset a casio g shock watch
HOW TO set your time on a G-Shock watch - YouTube
? 0:56
https://www.youtube.com/watch?v=_cwKYE1JMXM
Apr 8, 2013 - Uploaded by JseanSSent
This is a how to video on setting your G-Shock. ... Casio GSHOCK GA110GB-1A REVIEW ' How To Set Time ' LIGHT DISPLAY - Duration: 2:59.
Reset gshock - YouTube
? 1:41
https://www.youtube.com/watch?v=s6XVUqui6Nw
Jun 7, 2014 - Uploaded by aswan yusof
Tutorial how to reset gshock after changing battery. ... Reset gshock .... GA110-1B Stealth Black Casio G-Shock WatchReview - Analog DIgital ...
Dec 29, 2015 | Casio Watches
My g shock ga 100 keeps resetting itself back to 12:00 and the analog doesn't stay synced to the digital i have had a new battery fitted and it still doesn't work any suggestions ??
Did you take your Casio to a pro or it was just a normal battery replacement service?.
I am asking because if a pro did it seems he forgot to reset your Casio watch when battery was replaced.
This is a must when you change battery on a Casio digital watch.
Take it again and ask for a complete reset, if they know what they are doing they will do as you ask without questioning.
Casio Watches
Jul 02, 2014 | Watches
Reset time on casio g shock
Click on my profile and browse through my tips and tricks till you find link to all Casio watch manuals. Use that link and follow instructions. Rate me, please.
Jul 05, 2010 | Casio G-Shock GW500A-1V Wrist Watch
How can reset the reciving indecator ona g shock watch manually?
You can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals", watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Click on "search" and the download your instructions.
Mar 19, 2010 | Casio G-Shock Atomic MTG930DA 8VCR watch
How to use the stop watch function
On Casio digital watches you need to cycle through the modes till you get to the chronograph (stop watch). Once there you can use the start stop button to start and stop the chronograph then use the reset button to set back to 00:00:00 when you need to start over.
Sep 17, 2009 | Casio Watches
Don't know how to reset watch
Follow this link:
http://world.casio.com/wat/download/en/manual/
Rate me, please.
Apr 08, 2009 | Casio G-SHOCK 200M DW5600E1V Wrist Watch
Watch is blank/not charging
The watch started working by itself.
Jan 18, 2009 | Casio G-Shock GW500A-1V Wrist Watch
Reset time on Casio G Shock
how to set time on my g-shock watch dont have my manaual.
Nov 02, 2008 | Casio G-Shock G2600 watch
Please help me to replace battery on my casio F-91W
This reset trick works with other Casio Alarm Chrono digital watches, such as my old Model W-720, similar to your F91-W. After the new lithium coil cell is installed and secured with the spring clip, the watch may show random segments in the LCD display or may simply be blank. Insert a sewing needle, paper clip, or blade of a small jeweler's screwdriver into the hole on the back of the movement stamped "AC" (All Clear) to momentarily connect the gold plated contact at the bottom of the hole to the stainless steel battery clip. The battery clip in most such Casio watches is connected to the "+" terminal of the coin cell. This will reset the CMOS chip and it should start up with the watch displaying 12:00 and the date at 1-1. Then, use the control buttons to set the time and date in the normal fashion.
Aug 14, 2008 | Casio F91W-1 Wrist Watch
Battery replacement for a G-shock.
The reset trick works with other Casio Alarm Chrono digital watches, such as my old Model W-720, as well. After the new lithium coil cell is installed and secured with the spring clip, the watch may show random segments in the LCD display or may simply be blank. Insert a sewing needle, paper clip, or blade of a small jeweler's screwdriver into the hole on the back of the movement stamped "AC" (All Clear) to momentarily connect the gold plated contact at the bottom of the hole to the stainless steel battery clip. The battery clip in most such Casio watches is connected to the "+" terminal of the coin cell. This will reset the CMOS chip and it should start up with the watch displaying 12:00 and the date at 1-1. Then, use the control buttons to set the time and date in the normal fashion.
Mar 24, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Casio G Shock Tough Solar Digital Sports #G2800B1V Watch for Men Logo
2,537 people viewed this question
Top Casio Watches Experts
Janelle Schoonover
Janelle Schoonover
Ekse
Bruce Robin
Are you a Casio Watch Expert? Answer questions, earn points and help others
