click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enablewindows 7
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click selectconfigure speech recognition then you will see earphones with a speaker among a list set up a microphone headset with microphonethen next and next againyou should see your earphones with microphone being configured click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it hope this helps
do you mean you have no sound from your speakers or volume from your headphones??? click start control panel
has a tick in it or select the voice tab and make sure that you have the right
in it click start control panel
untick it hope this helps
untick it:
if your computer came with
a motherboard disc the sound drivers could be on it: click start control panel
administrive tools computer management device manager scroll to sound,video and
game controllers you might see a yellow question mark? Right click to reinstall
drivers click start control panel
sounds and audio,volume,advanced,speakers make sure you have selected the (((appropriate speakers)))
also audio you will find 3 drop down lists make sure you have the correct
settingsthere also click start control panel
untick it click start control panel
sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place
icon in taskbar if his does not fix the
problem click start control panel sounds and
audio,volume,advanced,speakers select the appropriate speakers from the drop
down list or navigate to the device manager scroll to system devices + to
expand,system speaker right click properties then select use this device
(enable) also you might check the speakers plug/outlet is
usually at the back of the computer you will have to open up the computer
to check the lead attached to the rear of the input plug make sure the
connection is good try cleaning your computer of dust using a fine air blower from a
compressor making VERY sure that there is no MOISTURE in the air line
specifically around the sound card and the CPU central processing unit dust
causes static to build up in a computer hope this helps:
If you are having problems with you sound if your computer came with a motherboard disc the sound drivers could be on it click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the (((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settingsthere also click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar if his does not fix the problem
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in ithope this helps click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enablewindows 7 hope this helps
if you want to off the microphone click start control panel sounds and audio devices select advanced there you can a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has or has'nt got a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has'nt a tick in it click start control panel sounds and audio devices select advanced there might not be a tick in the mute box tick it although it should not interfere with any listening to your music there might be another issue if your computer came with a motherboard disc the sound drivers could be on it click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the (((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settingsthere also click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar if his does not fix the problem
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
problem
have you tried this control panel sounds and
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it if your computer came with a motherboard disc the sound drivers could be on it click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the (((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settingsthere also click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
You don't specify what type of microphone you are using.
The following instructions apply to a microphone plugged into the normal mic/line in (red) jak-plug socket on most computers.
If you are using a USB microphone the process might be slightly different because the system has to actually recognise the microphone first. Most are plug and play so will automatically be detected after a few seconds but some do need drivers installing from the mic manufacturers disk
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
In the Sounds & Audio Devices Properties window locate the SOUND PLAYBACK box and click the VOLUME button. Make sure that there is not a tick (check-mark) in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Also make sure that the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here you need to SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK.
That should be it.
on your computer, under device manager, uninstall all USB devices, upon completion right click the top of the tree, click scan for new devices. this will reinstall the usb devices. then plug in your ext hard drive
