I have a problem about my psp thru to my computer.when i connect via usb connection psp to computer, it appear like "cannot install this hardware there was a problem installing this hardware and the system cannot find the file specified". that was my problem,so i cant download games thru my pc to my psp. plssss help, i begging you. Sir/mam expert...
Hook up your Sony PSP to your computer via a USB cable. Turn on the PSP and put it in "USB CONNECT" mode (it should display the words "USB CONNECT" on the PSP display during the entire time you're transferring files, and plug it in if you don't have a fully charged battery).
1. Connect your PSP to your PC via the USB cable. 2. On your PSP's menu, go all the way left into the Settings menu. 3. Scroll up to the USB Connection menu and click X 4.
Your PC should recognize your PSP. You can then access your PSP's
installed memory stick just as you would any other drive. Let's say,
for example, your PSP is now drive G:\ on your Computer. On your PC,
click into drive G: 5. Click into the PSP Folder. If this folder does not exist, you can create it by clicking File --> New --> Folder 6. Click into the MUSIC Folder. If this folder does not exist, you can create it by clicking File --> New --> Folder
Here you can drap and drop [or copy and paste] all of your MP3 or WMA
files and they should appear on the PSP's music menu.
Hi. First, you have to format your memory card so that the required folders will be automatically created.
On your PSP, go to Settings>>System Settings>>Format Memory Stick. Select YES when asked if you really want to format your memory stick. Wait for a few seconds & once prompted that it's done, you can now grab your USB cable and plug your PSP to a computer.
Go to Settings>>USB Connection. Your computer will detect the memory stick as an external drive. Once connected, navigate to your PSP's memory card directory via Windows Explorer. You should see an "ISO" folder. Open this and copy your downloaded games here (.iso or .cso file).
Safely remove the USB connection once done. Navigate to your "Games" on the PSP and the copied game will appear.
try to use another usb connector cable with your psp. It has some lost connection...maybe the data connector is loose. USB has 4 pin(pc side) the voltage supply for power and the data pin..just try.. if it doesnt work...checked if your in admin account because some hardware cant be installed if your not the admin of the pc.
yes its possible. first install motorola phone tools on your computer. then configure the phone setting/connection/data/fax connection. then connect the phone with usb cable. then click default profile-ok. it detects your phone. when the phone appears in the right down side of your pc,then click connect to the internet button. cofigure the connection according to your service provider and continue the process. any further infomation contact with me at 008801714731453.
im not actullay sure how you download through the psp. but i do know via computer.
download the song you want.
get your usb connection connected to psp.
go on psp and press (x) on usb connection.
then go to my computer.
open the psp memory stick.
put song in MUSIC
what should happen? the psp will charge and the laptop will alert you that a new device has been connected. after installing the device you should be able to transfer files between the computer and the psp.
You must have a memory stick to put music into your psp such as mp3 files, the psp itself does not have any internal memory for you to store any music files whatsoever.
if you got a memory stick already, connect your psp to your computer via usb cable, select usb under the setting section of your psp, and the memory stick drive will appear in your "my computer", so you can drag your music into the Music folder of your memory stick and play them from your psp.
