RCA HD52W58 52" TV Logo
Question about RCA HD52W58 52" TV
Can i connect my audio and video cable to a coaxial cable? so one side is coaxial cable and the other is audio and video cable one for the the wall and the other audio and video for the tv, this is beause my Coaxial input jack on the TV broken off so I cannot connect my coaxial cable from wall
Posted by betto2017 on
Chi Chu
  • RCA Master
  • 8,457 Answers
U have HDMI ports,order HD from the cable or telicom compannies.Use a HDMI cable for the tv,also get HD channels.Do not have HDMI ports than ur Main signal board must replaced the Antena analog coaxial it broken.Well not able to buy the coaxial input for the antena along for part.
Posted on Jan 10, 2010
How do I hook this tv up with a cable box?
  1. Turn off and unplug the TV and cable box. ...
  2. Hook up one end of a coaxial cable to the cable wall outlet and the other end of this cable to the back of the cable box using the "In" jack.
  3. Connect one end of the RCA audio/video cable to the back of the cable box using the "Audio/Video Out" jacks.
Give me properly installation of stand alone dvr with computer all window how sport the dvr send me properly anstallation of standalone dvr
Take one co-axial cable, and connect the "input" port to your cable-company's wall-port.
Look at the connectors on the back of your TV. You could have:
* coaxial input (lowest video-quality)
* S-Video input (better video-quality)
* component input - three cables for video, two cables for audio (better video-quality)
* HDMI input (highest video-quality)
Look at the connectors on the "output" side of the PVR. You could have:
* coaxial output (lowest video-quality)
* S-Video output (better video-quality)
* component output - three cables for video, two cables for audio (better video-quality)
* HDMI output (highest video-quality)
Connect the "outputs" to the "inputs", using appropriate cables.
Turn the PVR on. Turn the TV on.
Use the "source" button on the TV's remote-control to select from the various inputs
(Coax, S-Video, Component, HDMI1, HDMI2).
If your TV has 'PIP' ("Picture-In-Picture") capability, connect more than one output to a second input, so that both tuners inside your TV will receive a signal.
I want to connect my Pioneer XV-HTD520 receiver to Dish Net to provide music throughout my residence. I was connected to Direct TV until 1 week ago, everything worked fine but I was connected directly to...
I think we're both confused.
We need specific details when talking about AV gear because of the common interchangeable terminologies (but NOT fuctions) and cable types used by the audio and video sides.
Let's be specific about types of cables:
Coaxial Cable (for TV) = 300-ohm like an antenna conenction
Coaxial Digital Audio = RCA-style cable
Just because something fits doesn't mean it carries a compatible signal.
The closest thing I could find to describe the unique inclusion of a TV-style coax on the back is this:
http://forum.ecoustics.com/bbs/messages/3/84929.html
Is the HTD-540 capable of tuning TV stations (wall coax)? I doubt it.
The wall coax is for multiple TV channels, right? It's not the same as running a video coax from, say, a VCR on Channel 3, or is it?
Please clarify, if possible.
This statement, too, is puzzling, "but there is a TV >>> wo/output<<< jacks in the same cabinet ".
Common abbreviations I am familiar with would be w/output (WITH output) or w/o output (WITHOUT output). Which is this?
In either case, what is the relevance of output jacks on a TV? Unless you mean AUDIO output. Even so, why wash audio through a TV then send it via probably analog-stereo-only RCA cables to an audio-specializing device like the Pioneer?
I'd like to know where the vcr cable & cable wire from wall
(I own 2 VSX-D903S Units.)
There are NO optical (Toslink) or coaxial connections for Satellite or Cable-TV on this Pioneer unit.
The coaxial connector on the receiver is for connection to an external antenna for FM Tuner (radio) reception only.
Your cable line from the wall would go to your Cable Box, or a "cable-ready" TV or VCR. You would then connect the composite (YLR) or S-video output A/V (S+LR) connection to the VCR 1 input on the back of the receiver. Connect your TV L/R audio and S-video or Composite video output to the TV in connection on the Receiver. (Connect the Composite TV-out connection to a composite video-in connection on the TV.)
Hot to hook up cable
This monitor with a television tuner does not have a coaxial connection. I was able to get cable by connecting (buying if you don't have) to my dvd/vcr which had the coaxial connectors. Then I ran the video component cable (green, blue & red - had to buy that) from the tv to the dvd/vcr. Then I ran the audio cable (red & white) from the tv to the dvd/vcr. A little tricky figuring out where on the tv to actually connect but eventually got it. YUV2 on the side.
Connecting VCR to TV
Oh man dont shoot your stuff instead use your remote and go to your menu and select your input. You tv is looking at your coaxial input but you can select which input you want. 1, 2 front back whatever you need. channell 3 or 4 has nothing to do with connecting up your dvd if you connect and choose the front connection in your menu.
1helpful
2answers
How do I hook up a dvd player recorder to my tv, so I can record? thank you DEE
Hi dbird30,
You will notice that your DVD player has two types of cables, one that is three cables in one with yellow, red and white colors; and other that is bigger and cylindrical, we call this a coaxial cable. To record from the TV you must unplugg the TV's cable and plugg it into your DVD player, plugg it where it says 'cable' or 'input'. Now you must connect the coaxial cable it came with your DVD player and plugg it into the DVD player where it says 'to TV' or 'output' and connect the other side of the coaxial cable to the TV. At the end you should see that the cable that was plugged into your TV is now plugged into your player, and the player is now connected through another coaxial cable to the TV.
2helpful
Need directions to install a dch70 box to tv
dear woolifer ,
I am not an expert but i hope i can help you..
is it youmean digital cablebox?
if it is try this-
This is a problem a lot of people have with coaxial-only televisions because DVD players do not have coaxial (RF) outputs, which means they can't be connected directly into a television with only a coaxial (RF) input. The solution is to purchase a RF modulator, which is a small device that will convert the AV output from the DVD player to coaxial (RF).
As for the instructions, I am going to assume the DVD player is not a combo unit with the VCR, and that you want to record TV on your VCR. Step 4 will include connecting your DVD player, but if the DVD player is a combo unit with the VCR, just ignore step 4 part as DVD connection will be included in the VCR set up. Actually, you wouldn't need the RF modulator if it is a VCD/DVD combo unit.
  1. Connect the coaxial cable coming out from the wall to your digital cable box in the ‘video in’ slot. It might also be labeled ‘antenna in’ or ‘cable in’.
  2. From the cable box, connect a coaxial or composite (yellow video cable) and stereo (red-white) RCA audio cables to the VIDEO IN terminal on your VCR.
  3. From the VCR, you will have to connect this to the RF Modulator using a coaxial cable from the VIDEO OUT on the VCR to one of the IN ports on your RF modulator.
  4. You can now connect your DVD player to the RF Modulator by using the yellow-red-white composite/RCA cables from the VIDEO OUT on the DVD player to another port on the RF modulator.
  5. From the RF modulator, connect this unit to your TV by using a coaxial cable. It will be from the VIDEO OUT on the RF modulator to the VIDEO IN or CABLE or ANTENNA IN port on your television.
This should be all you need to get started watching your digital television. In simple terms here is what you did:
Coaxial from wall to cable box
Cable box to VCR
VCR to RF modulator
DVD player to RF Modulator
RF modulator to TV
You will only be able to record what is on channel
Top RCA Televison & Video Experts
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
