Question about DeLonghi PAC C100 Air Conditioner
Leaking After the air con has been on a while it leaks water all over the floor.
Posted by debclee919 on
rolando ingking
  • 832 Answers
Please check the water container for leaks. Normally,
it does not leak, since the water is supposed to evapo-
rate due to compressor heat. The water that the aircon produces goes to a containing pond near the compressor. So that if there is a leak, it emanate from
this area. May this tip help you.
Posted on Jan 10, 2010
Air con leaking water on passenger side floor
most likely a blocked drain hose from the bottom of the ac cabinet
they have a tendency to block up with greasy gunk and can be cleaned with a piece of wire compressed air
Jan 01, 2017 | Cars & Trucks
Tip
How to stop portable air conditioner leaking water
I heard that some portable air conditioners can leak water from the unit after being operated for about an hour or so if they are not on a level floor. <br /> I solved this with my DeLonghi air con after discovering the floor my unit was on had about 1 - 2 mm difference from one side to the other. By buying a small builder's liquid level (like you use to keep a line of bricks aligned) I used a small piece of wood (ruler thickness) under one side of the air con and no more leaks! Hope this helps someone. Kez, Perth WA
on Jan 30, 2011 | Heating & Cooling
Model 645. Why did driver side rear footwell fill with water?
Water leak check:
1. Plenum chamber leaks at loom exits (Accident damage or corrosion)
2. Water leak at air con fan inlet (Accident damage or gasket wear)
3. Water leaking from air con heater pipe (corroded water pipe to/from heat exchanger)
Oct 28, 2015 | BMW Cars & Trucks
Water getting in car
If the front footwells are getting wet it is possible that the heater core is leaking .Are you losing radiator coolant? the other possibility is the air con drain tube is blocked or fallen off.
Feb 12, 2014 | Emission System for Infiniti 5 J30
Water leaks under portable air con unit
Look for a crack on the water tank or a dried up gasket on the tank. Loose hose clamps can allow a leak as well.
Jan 04, 2014 | Heating & Cooling
Water leak from Electrolux Kelvinator EPK09CRN2A portable air conditioner
You'll have to open it up and check for a displaced condensate collector. This may look like a funnel with a drain tube that is supposed to go to the tray
Nov 28, 2012 | Electrolux E23CS75SS Air Conditioner
DeLonghi PAC C100 Air Conditioner Logo
1,442 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Sheldon Dedek
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
