Cameras Logo
Question about Cameras
My Pentax Optio 450 retains only one photo on the memory card
My Pentax Optio 450 only shows the last photo taken, apparently losing the ones taken before. Says ''Camera cannot display this image.'' Naturally, it started this behavior during a wedding. Boohoo. Any thoughts? Tried turning it off and on, popping out and putting back in the memory card and the battery.
Anonymous
    Brigadier General:
  • 11,967 Answers
Have you tried using a card reader to download the pictures from your card to your computer? I bet the pictures are there.
Posted on Jan 10, 2010
Testimonial: "Duh. Great idea! The pictures were indeed stored on the memory card. THANKS!!"
3helpful
SDHC 16 GB memory card compatible with Pentax Optio 450
No, you cannot use SDHC cards with the 450. You can only use MMC and SD cards, 2GB and smaller.
3answers
Photo recovery 12/9
It sounds like the memory card got corrupted. If the memory card shows no files, there are no files. I'm sorry, but they're gone. Are you SURE the pictures aren't on your computer? Most cameras delete the pictures AFTER it copies them to your computer.
My Pentax Optio S5z does not store images to SD
Copy your photos to the SD card in the camera. http://www.pentaximaging.com/files/manual/OptioS5z_web.pdf p. 136
Transfer all photos to your computer from your SD card, and then put the card back into your camera. Try looking through your manual to see if there are any other settings that are required in order to save photos to the memory card.
How do I delete the photos from my SD card?
Format the memory on internal and disc.
Vitally
5helpful
Memory Card Error on 4 Gb CF cards (80x) for Pentax Optio 430
The maximum supported memory for Pentax Optio 430 is 256mb and for Pentax Optio 430 RS is 512mb.
Check this site for more information.
Optio 430
http://www.upgradecomputermemory.com/ram.cfm//memory/P/Pentax/Pentax-Optio-430/
Optio 430 RS
http://www.upgradecomputermemory.com/ram.cfm/memory/P/Pentax/Pentax-Optio-430RS/
7helpful
My camera shows CARD LOCKED
Try taking the card out of the camera and clicking the side of the card - there may be a little gap on one side of the card or a small button that you can slide up and down and then reinsert your card.
23helpful
2answers
Unlocking memory card
http://www.pentax.de/downloads/photo/uk/Optio%2060/Optio60_Manual_web.pdf
pg 17 at the bottom shows how to unlock the card, but it is simple, take out the memory card and on the side of it will be a little tab which can slide, slide it off the lock position and it should work
2answers
Pentax optio m20
Usually this is not a problem and you will find a menu option to do this. But, in some cameras the solution is to download them the same way as the memory card by plugging in the camera to the computer. Remove the memory card, and then plug in the camera.
Top Cameras Experts
Marvin
Marvin
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
