Flashing f9 during wash cycle - Washing Machines
Posted by dlstagaman on
Anonymous
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 50 Answers
Overflow Condition
If the Overflow contact on the pressure switch is Closed for more than 60 seconds and Overflow condition will occur. In an Overflow condition, the Door will remain locked, and the Drain Pump will run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service.
  • Check the drain hose and make sure it is not plugged or inked.
  • Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
  • Check/Clean Drain Pump Filter of foreign objects
  • Check for Drain Pump Failure
  • Check the Inlet Valve for proper shut off
  • Check the Pressure switch for proper operation
Posted on Jan 10, 2010
How to stop the water?
Not knowing what brand / model you have makes it difficult however, the basic symptoms of a water problem are; If the water keeps coming into the machine with the power off and the tap on, it will be a valve fault. If the water keeps coming in with power on and on a wash cycle, its likely to be a fault with the pressure switch, pressure tube (Split or hanging off) or an electronic failure of the control board.Lastly, check the drain hose. If the end of the hose is lower than the water level of the machine, it is possible for the machine to start syphoning itself. Espe3cially just after the first pump out (Start of Rinse cycle) Make sure the machine is actually pumping water out. If it cant pump out, the machine may try to refill but it is already still full from last wash , causing the error code to flash. Check for pump jamming up with foreign objects, or hoses blocked with a sock, lint etc.. Sorry but cant help much more than this.
Sep 02, 2014 | Washing Machines
Nordmende dishwasher dfsn60
nordmende dfsn60 error code f9 , the dishwasher is stuck on the 4th cycle but not washing and error code f9 appears how can i fix this
Jan 05, 2014 | Televison & Video
Washing machnie hitachi sf 100 fjx displaying F9 during rinse
hitachi washing meching not worjing display f9
May 02, 2012 | GE Washing Machine
F9 error message during self cleaning cycle
Hello,F9 error means there is a problem with the lock switch.Check the wiring to the door lock switch (the wire harness may be connected wrongly).Check for stuck lock switch.
Thanks
May 31, 2010 | GE Monogram ZET3058SHSS Stainless Steel...
F9 Error during self cleaning cycle
Before you go working too hard to get you oven to go into the self clean (self destruct) mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
May 31, 2010 | Ovens
F9 Code
Pump is most likely clogged .... take front panel off and pump is right there ......
Jul 22, 2009 | Kenmore Elite 45986 Front Load Washer
Wet cloths need help please!!!!!!!
F9=Overflow Condition
Nov 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
No spin or drain!!!!
F9 is a water pump problem, either clogged pump, or pump malfunctioning, Check for something clogging the water pump
also there may be water and air stuck in the pressure switch tip
Jul 27, 2008 | Whirlpool AWM6141/1 Front Load Washer
Error codes
if this is a fridgidaire washer, I guess it's a clogged coin catcher. You have remove the front access panel and clean it out. I am working on that now.
Nov 05, 2007 | Washing Machines
Washing Machines Logo
158 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
