Question about Pioneer DEH-P4000UB CD Player
How do i change the time on my deck - Pioneer DEH-P4000UB CD Player
    New Friend:
  • 50 Answers
Adjusting initial settings
1 Press SOURCE and hold until the unit turns off.
2 Press MULTI-CONTROL and hold until CLOCK SET appears in the display.
3 Turn MULTI-CONTROL to select CLOCK SET (clock)
Setting the clock
Use these instructions to set the clock.
1 Use MULTI-CONTROL to select CLOCK SET.
2 Press MULTI-CONTROL to display the setting mode.# Press BACK to return to the previous display.
3 Press MULTI-CONTROL to select the segment of the clock display you wish to set.
Each time you press MULTI-CONTROL, one segment of the clock display is selected.
As you select segments of the clock display, the selected segment blinks.
4 Turn MULTI-CONTROL to put a clock right.
# You can also perform the same operations by pushing MULTI-CONTROL up or down
Posted on Jan 10, 2010
Testimonial: "thanks very much now i can tell time in my car lol "
How do l tighten theblade belt on a 2010 Bolen riding lawn mower?
The blades should only be engaged when the tractor is rolling for one, deck heighth has a lot to do with the blades turning did you just change the belt? if you did did you make sure the deck height is correctly situated, meaning according to the heighth of the deck when you changed the belt, you could also not have the belt around all the pulleys or the belt may beworn out
Apr 04, 2016 | Garden
Ad-f410 change pinch roller
Why do you want to change the Pinch Roller? Most of the time they just need a good cleaning and other things in the deck like back tension checked. Pinch Rollers are only changed if they are cracked and I have seen few cracked Pinch Roller in 40 years.
May 02, 2014 | Audio Players & Recorders
How do I change the belt on my panasonic stereo double cassette stack
You get the belt kit from Marrs Communications and then take the unit apart and put them in. After putting new belts into a mechanism the next test is to set the speed to the correct value using a wow and flutter meter or a frequency counter and speed alignment tape. This is why belts are usually installed by a Tape Deck Technician. I hear the complaint all the time that I changed belts and my deck does not work now- well that is why they are changed by a Technician, he will oil the bearings, lubricate the mechanism and install the belts in the right place without breaking anything. It is not always a 5 minute job. That is why they charge for this because it take a few years of doing them before you are good at it.
Like I have told others- dual cassette decks usually do not warrant the cost of a repair and most of them are considered throw away.
As to the direct answer to you question -there is no manual that gives you step by step instructions- at least in 40 plus years of working on decks- I have never seen one.
Mar 10, 2013 | Audio Players & Recorders
Weslo cadence g40 stops for no reason
you must LUBE THE deck belt by aprox 150 miles. In according with the schedule maintenance,
Please LUBE the deck belt+rollers bearing.
see the video
If the problem persist time to replalce the OLD board deck belt.
God bless you
Jan 22, 2013 | Weslo Cadence G40 Treadmill
Contiually beeping, when started it stops a few seconds later
LUBE the deck belt+ roller bearing too. see the video and proceed according. If the problem persist after you lube , time to change the deck belt board complete.
God bless you
Jan 08, 2013 | Nordic Track NordicTrack T7 si Treadmill
2003 hyundai tiburon dual din JVC touch screen deck installation issues
Hello, Chose another powersource for your device. It is possible that you are tied into a circuit breaker that is constantly resettting. Maybe use an MP3 player for the trip and work on it when you get back.
Dec 09, 2011 | 2003 Hyundai Tiburon
Have a 2000 Simplicity Landlord tractor with 54 inch mowing deck pull switch to engage deck and it will not engage, looking for answers thanks
Tou have a broken or loose deck belt. Not an easy DIY but medium and doable. Check the belt in the deck too (the one that makes both blades spin at the same time. This belt likely needs to be changed too.
Aug 18, 2011 | Garden
VCR runs 10-15 sec. shuts off.
most vcr decks are clones of other decks .find out what deck is fitted in that model ...might find that a easier way to trace a service manual. check R.S components parts ..i'm sure they have a section on vcr decks and a large parts and service sections with pictures to help you identify your deck. ps if you have never done this sort of thing before i would think hard on whats involved it can be very time consuming and awkward to do....deck timing can be a real pain to get right. i would start with the easy things to change first like the pinch roller.anyway hope this helps a bit ..farr64
Apr 27, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Replace blades on a john deere L120 mower deck
First make sure you have the tools, metric that is. The deck must be removed and turned over. To do this you must put the deck in the lowest position. Using a 15mm socket pull the belt tension spring pulley forward to detach from clutch. Next remove retaining pins located at the five deck brackets. This will allow the arms to slide off and the deck can be dragged out from under the mower. Turn deck over. Use a 18 inch 2x4 to block blades while removing the two 15mm bolts. The bolt heads will need to be cleaned so the socket can seat on bolt head. I use my torque wrench to get more leverage and i can use it to reset blade bolts to 64 ft lbs. While blades are of it is a god time to thoroughly clean underside of deck.
Apr 04, 2009 | Garden
Pioneer DEH-P4000UB CD Player Logo
742 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Sumeet Sodhi
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
