Question about Optics
Simmons aetec, put on muzzleloader to boresight and adjustments work in reverse.
Posted by dwwills on
Mark Campeau
    New Friend:
  • 44 Answers
It's a common misconception to think that you're moving the bullet impact on target, when in fact you're moving the scope's reticle to look where the rifle is shooting.... So if your shooting left of your target.. you want to move the crosshairs to the right.
Hope this helps, mark the Gunsmith
Please leave feedback, Thanks!
Posted on Jan 13, 2010
How can I use my boresighter on my silent cat Gamo air rifle.
There is a small screw under the front sight. take it out. then work what will turn out to be just the grey front to the baffle, out. pull it from the bottom as that is where the longer insert is. u will then see the blue plastic off the baffle. it tugs out. then ull c the end of the barrel, Boresight fits inside grey baffle cover. happy shootinnng
Sep 22, 2014 | Gamo Silent Cat .177 cal. Break Barrel Air...
Repair scope barska
Most likely a 2032. Most common battery used.
Nov 12, 2013 | Simmons Aetec Riflescopes
My scope has moisture in it. How can I get it out
At the factory they fill the scope with nitrigon to keep them from fogging once it is gone the only way to fix it is send it back to the factory. Good luck.
Nov 17, 2009 | Simmons Outdoor AETEC 2.8-10x 44mm WA...
I have a brand new SIMMONS AETEC 2.8-10 power. The power adjustment dial is extremely stiff. What could be the problem?
it has rubber "o" rings in it and they do get tight if its a new scope it will free off in time,,, but to free it off faster give it a realy good twisting fully to each way i very much dought that spraying any wd40 on it will get into the scope but if it did and any got onto the lenses its a bust bin joby just put up with it being tight till it frees off,, simmons scopes are not the best of scopes
Nov 14, 2009 | Optics
I'm looking for a manual or instructions for a rifle scope simmons blazer model 800506? Scope has a boresighter built in; I'm not sure how to use.
your best bet is to locate your local shooting club and ask someone experienced with specialist scopes. As for now, all I can suggest is to sight the scope in at 3x power. I'm not sure about a boresight on this scope, since is is at the extreme budget end of zoom scopes. If you mean it has a rangefinding (or ballistic) reticle, then you might try here: http://www.perry-systems.com/reticle_analysis.htm for basic usage guide. The reference distances will vary according to several factors, including but not exclusively: bullet weight, muzzle velocity, firing angle, windage adjust, wind direction.
Jul 21, 2009 | Optics
I set up my lazer boresight and adjusted the cross hairs to centre. after the first shot i put the boresight back in the gun and every time the cross hairs are out. i have checked the alun screws and they...
It sounds like an internal problem which you, yourself may not be able to repair.
Go to; www.iorvaldada.com/niviriscriop.htm (UAS Optics) they are the dealer for this scope, or their email; [email protected]. or their phone; 813-495-7951.
They should be able to assist you with this problem. Good luck. :)
Mar 14, 2009 | Rigel Optics 4100 Weapon Sight
Non-muzzleloader use
I never thought about it but I don't see why it would not work.The only issue would be recoil, and recoil is recoil.I am considering putting a scope on my Sharps replica and only wish it to look authentic.Good Luck
Nov 29, 2008 | Omega Nikon Muzzle Loader Rifle Scope...
Optics Logo
138 people viewed this question
Top Optics Experts
Marvin
Marvin
ray gallant
Are you an Optic Expert? Answer questions, earn points and help others
