Question about TriPro Power (POW-1000AS) UPS System
TriPro power UPS Systems 400
I have a TriPro power UPS Systems 400 and it has a light has come on that reads (building wiring fault)What do I have to do to repair this problem?
Posted by almd4f on
Anonymous
    Scholar:
  • 39 Answers
If UPS is displaying "Site Fault", it is doing its job correctly. You need to check the wall receptacle. Probably hot and neutral reversed, or the neutral and ground are reversed, by whom ever installed the wall receptacle. You need to have the plug-in for the UPS intact, i.e. the ground pin must not have been cut off. If an extension cord connects the UPS to the wall, the cord must be working correctly.
Posted on Feb 11, 2011
Anonymous
    New Friend:
Throw it inside water
Posted on Jan 11, 2010
Replaced battery but system is still chirping. replace unit?
i suspect the inverter circuit of your UPS is already faulty... btw can you give us more detail on this problem?
Mar 22, 2012 | TriPro Power Tripro Maruson Technology UPS...
My Microtek ups (HGE600AZ) is not giving back up after the power cut ?
hi
I want to purches battery for HGE 600 AZ Microtack UPS.
Please give me contact No. of athorize diller No.
Dec 24, 2010 | TriPro Power : UPS Pro 650VA (PSTP06) UPS...
Tone alarm goes off and flashes "overload" and on the back "building wireing fault" is lit up
The "Overload" light and alarm is to tell you that the devices connected to the UPS are drawing more current than the UPS can safely provide with battery backup. You should disconnect a few items, and the alarm and overload light will turn off. The "Building wiring fault" light on the back is to tell you that there's no proper ground wire inside the wall outlet that you're using. These two problems are not related to each other.
Mar 04, 2010 | APC Back-UPS® XS 900 (BX900R) UPS System
The unit is beeping and the red light over the battery symbol ont he right hand side is blinking. Wiggling the main power cord to the unit has been the only solution. I am wondering if the system needs to...
Probably, the battery inside the unit has reached its "end-of-life".
The RED light near the BATTERY icon is the indication.
Remove the battery, and check the date on the battery.
If it is "too old", it should be replaced.
There do exist companies that will take your battery, open it up,
replace the rechargeable cells, and ship it back to you,
for a lower price than buying a brand-new battery.
Jan 04, 2010 | TriPro Power : Smart 1500VA UPS System...
Wireing Fault Light is On
check the phase rotation of ups input, if it is a 3 phase input
Oct 14, 2009 | CyberPower 525SL (CPS525SL) UPS System
Durning an electrical storm the ups shu toof and now does not work is there a switch or fuse that needs to be replaced vern
No electronic equipment should be uswd during electrical storms. There is always a fuse at the back of the device. Unscrew it and check the glass viol for a broken wire inside. If yes, then replace it with the same specification viol. If not then the damage is serious and needs professional help.
Aug 16, 2009 | TriPro Power Tripro Maruson Technology UPS...
Ups in problem
Your inverter shorted. Get another one.
Sep 06, 2008 | TriPro Power (POW-1000AS) UPS System
TriPro Power (POW-1000AS) UPS System Logo
209 people viewed this question
Top TriPro Power Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a TriPro Power Computer and Internet Expert? Answer questions, earn points and help others
