Question about Uniden DECT 6.0 Cordless Telephone Expansion Handset
I dont have an owners manual and just wondering how to switch the setting from pulse to tone
  • Uniden Master
  • 8,081 Answers
  1. Press MENU/SELECT.
  2. Select the Global Setup menu, and then the Dial Mode submenu.
  3. Scroll to highlight Tone.
  4. Press MENU/SELECT. You will hear a confirmation tone.
If you ever need to change the dial mode back to pulse dialing, follow the same procedure, but select Pulse in step 3
Posted on Jan 11, 2010
Selecting dialing mode
The directions for changing the dialing mode from tone to pulse can be found in the owner's manual for the main base unit.
Press the [MENU] button then choose "Set tel line". Then choose "Set dial mode", then choose Pulse or Tone and press [OK].
Additional details can be found in the below link.
http://service.us.panasonic.com/OPERMANPDF/KXTG1031.PDF#page=14
Jun 28, 2014 | Panasonic KX-TGA101S Cordless Handset
I have got a Panasonic KX-TG7220NL. Cannot change from pulse back to tone. How to do that?
First of all, here is the main ONLINE SUPPORT page for your model:
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Telephones/Bluetooth-Enabled-Systems/Operating-Instructions/model.KX-TG7622B.O#ts
And here is a direct link to the ONLINE USER'S MANUAL for that model:
http://service.us.panasonic.com/OPERMANPDF/KXTG7622-MUL.PDF
To view the Support Page or the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 18 of the manual for detailed instructions on how to switch between TONE and PULSE dialing. Basically it reads as follows:
Dialing mode
If you cannot make calls, change this setting according to your telephone line service.
The default setting is "Tone".
"Tone": For tone dial service.
"Pulse": For rotary/pulse dial service.
1 - MENU # 120
2 - Use UP / DOWN arrow keys to select the desired setting.
3 - Select SAVE and then OFF
I hope that was helpful to you, good luck and take care.
Joe.
Aug 26, 2011 | Lands Phones
Hello, could you please help me with my panasonic kx-tc1200bx? How can I switch tone/pulse dialing tone? Thanks! Best Wishes.
The owner/user manual should have instructions on how to accomplish this. I take it that you no longer have the manual, so you'll have to root around in the phone's settings (you may have to access the tone/pulse setting from the base unit), to select the desired dialing mode. On some older phones (including cordless), the tone/pulse selection is a physical switch on the base unit (on the top/bottom/side/back). Look carefully... I hope I've helped you!
Aug 13, 2009 | Lands Phones
Faxing on pulse line Brother Fax-575
HELLO! YOU WILL NEED TO GO INTO THE SET OF THE MACHINE, THERE IS SECTION THAT WILL ASK YOU PULSE OR TONE PUSH TONE THEN THE SET BUTTON GOOD LUCK
Feb 01, 2009 | Brother FAX-575 Plain Paper Thermal
Changing from pulse to tone dial
For the GE electric 2.4 GHZ phone where there is no switch, you have to press the program button and hold until it beeps (talk button will start flashing), then press the tone (star) button and program again. It will beep for confirmation
Dec 12, 2008 | Lands Phones
Switching from pulse to tone dialing (there is no switch on the base unit)
hold the select button down a few seconds until you'll see a 'tn' on the readout. this sets it to tone. hold it down again and it will set back to 'Pu' for pulse. i figured this out by accident. the losers at vtech never answered my question.
Oct 25, 2008 | Vtech 2467 Cordless Phone
Switching from pulse to tone and reverse
once tone/pulse appears there should be a way to hi light/select or choose either one.you must set it into memory. after it is stored, you shouldn't have to set it again before making other calls.
hope this helps
wg
Feb 10, 2008 | GE 29385GE1 Corded Phone
How to switch phone to tone
I found a manual from AT&T that had the information I needed. Thanks!
Sep 18, 2007 | GE 26920 Cordless Phone
Lucent Technologies 925 Phone
If memory serves, to program the touch tone, lift the handset, press [PROGRAM] # # # 3 then hang up.
May 24, 2007 | Lucent Speakerphone 925 (21248)
GE 29439GE2
Copy directly from the manual: TONE/PULSE Your phone is set to TONE at the factory. Set the TONE/PULSE selection to PULSE if you have pulse (rotary). If you don't know which type of service you have (pulse or tone), check with your phone company. To program TONE/PULSE for all 3 lines: 1. Press STORE/IN 2. Press 0 for PULSE or Press 1 for TONE 3. Press STORE/IN 4. Press TONE To program TONE/PULSE for each line individually: 1. Press STORE/IN 2. Press 0 for PULSE or Press 1 for TONE 3. Press STORE/IN 4. Press LOWER 5. Press line number (1, 2, or 3)
Jan 11, 2007 | GE 29439GE2 Corded Phone
Uniden DECT 6.0 Cordless Telephone Expansion Handset Logo
251 people viewed this question
Top Uniden Lands Phones Experts
Marvin
Marvin
martin hogg
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
