Question about Black & Decker Power Inverter PI400AB
My inverter started flashing its green light now it wont turn on, i have checked the internal fuse's they are good, next i checked the fuse's in my car and they are good, i even tryed plugung in another item, and they work. what could be my problem
Posted by tjthorn17 on
Anonymous
  • 714 Answers
This inverter is a good Walmart inverter.
I had one that worked for about 6 months.
There really is no affordable fix.
RECOMENDATION:
Take it back if you can as soon as you can, dont fix it..
Hope this Tip Helps.
r/
David
Posted on Jan 30, 2010
What causes a red light on an TB Wood Etrac XFC 1001 inverter and the motor will not start Is there an internal fuse Do I need 3 phase for the input
Is that red light flashing or continous lighting? You do not need 3 phase input for that model. Do you have the input wiring diagram? If the red light is flashing maybe the emergency stop input is active. If the red light is on continously then it maybe in stop mode or torque limit, ask electrician to check the wiring.
Dec 31, 2016 | Inverter Electronics - Others
Tv sreen wont turn on
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Dec 02, 2015 | Samsung Televison & Video
My digital tv wont come on even tho standby light keeps flashing would it be the internal fuse blown
No, if an internal fuse were blown, you would not have a flashing standby. Most likely you have a problem with the power supply but it could also be with inverter or driver circuits.
If it's a good set, take it in for repairs - if it's a cheapo, trash it!
Feb 02, 2015 | Televison & Video
New battery In mercedes no power
I'm not a car mechanic, but, it sounds like you might want to check the fuse to the ignition switch, and, if that fails, it might be a problem with the Start Safety Switch on the transmission. Good luck.
May 02, 2017 | Mercedes-Benz S-Class Cars & Trucks
My tv is plugged in but wont turn on, there is a green flashing light (timer) how do i fix this?
hi sir good day the green light indicator flashing which indicates error detected by processor. now here is my solution on how will you fix the problem. if you are going to do it with your make sure you have proper tools and at least a basic knowledge in repairing. now unplugged the unit then open the back cover to gain access the internal part of the tv. now disconnect the connector wire going to inverter board for back light then turn the tv, if the indicator stays green doesn't blink then all the voltage out put from the power supply is normal the 5v stand by,5v switch, 12v and 24v are present, you have bad inverter board or the back light itself. another way is if you disconnect the connector wire going to inverter ballast board then still light indicator flashing and no PS_ON voltage coming from the main board which switch the power supply to turn on i may say you have bad processor board. make sure no bulging capacitors at the power supply replaced it with the same value a panasonic brand FM or FC series much better with low ESR 105c rating. you can find replacement parts at www.digikey.com . hope this will help you feel free to ask further question good luck.
Aug 20, 2011 | Televison & Video
Hi, I overloaded my washer with towels. It hasn't fully drained (can hear water beneath the tub when you move it). I tried unplugging it for a minute, but the same problem presents itself. When start is...
The motor has a power inverter on top of it. Try and reset the motor by doing this:
Turn the washer off. Unplug the machine for one minute. Plug back in and raise and lower the lid six times within 12 seconds. It may take a few times. The motor has a green light on it that blinks. If it ain't acting right it will display flashes:
1 flash bad motor
2 flashes slipping belt
3 flashes corrupted software bad motor
4 flashes failed mode shift circuit
5 flashes little green men bad motor
6 flashes locked motor check for objects between tub
7 flashes bad lidswitch.
8 flashes motor overheated too much soap
9 flashes brake resister is toast bad motor.
After resetting the inverter board, put the machine in a spin cycle and see if it runs. If not, check for a green blinking light on the inverter board. It will flash failure codes according to the picture above. If no light you probably have a blown fuse built into the neutral side of the harness on the white/red wire.themobilian_4.png If you see a liitle bubble in there then you know that dude is toast.
That fuse is: $7.50
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 29, 2010 | GE Profile WPRE6150KWT Colossal Capacity...
Nintendo DS Lite not turning on
no there isnt a reset routine. have you tried the fuses.
do any of the screens flash when the green light flashes.
Jul 12, 2009 | Nintendo DS Lite Console
The blinking green light on VX922
If there is a flashing led on front of the monitor, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1 The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours, sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr suddenly are a blown capacitor on power board, the inverter board powering up backlight lamp has blown, or a fault on main lcd controller board.
check also the video cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Check connectors, try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact Viewsonic to find out a Viewsonic service point.
See:ViewSonic - Support & Service
If you want to repair at your own expenses, just locate any good qualified repairer.
Regards
Feb 26, 2009 | ViewSonic VX922 19" Monitor Flat Panel
Black & Decker Power Inverter PI400AB Logo
447 people viewed this question
Top Black & Decker Electronics - Others Experts
Sheldon Dedek
Vernon Taylor
Are you a Black & Decker Electronics - Other Expert? Answer questions, earn points and help others
