Question about Sony KP-53S70 53" Rear Projection Television
We just bought a used TV model number: KP-53S70.
We just bought a used TV model number: KP-53S70. After the hour ride home, we got it all hooked up and now it won't turn on. Is there something we are doing wrong? Does it need to warm up? It was working just fine prior to the hour trip in the back of a pickup.
Posted by khyme on
Anonymous
    Scholar:
  • 102 Answers
It is pretty clear something was jarred loose during the move; these are pretty delicate devices. You should NOT try to repair this yourself. These types of televisions can have LETHAL voltages inside for WEEKS after they are unplugged.
Posted on Jan 09, 2010
Screen went black you could still hear the tv, timer/standby light is blinking. Is there a projection bulb that goes out. Can this be an easy fix?
U have a LED light indicator said lamp on ur tv?It is blinking?If the LED indicator said lamp is blinking.Than yes,ur projection bulb require changing.Yes replacing bulb pretty easy.
May 01, 2010 | Sony KP-53S70 53" Rear Projection...
Is a sony big screen tv model number kp43ht20 a hd
Yes.The best way to hook up this set is using the Component input (R,G and B inputs) with red white for audio
see link to specs
http://www0.shopping.com/xPF-Sony-KP-43HT20
Oct 30, 2009 | Sony KP-43HT20 43" Rear Projection...
My Tv made pop sound and now the red lifgt blinks 4 times.. And no picture. any idea what I need to do and the cost?
Hi,it sounds like you lamp went bad.If your tv is between 2-4 yrs it will be the lamp that needs replacement,The red indicator is indicating there's an issue with the lamp.Try this websites discount-merchant or, discounttvlamps, They carry the original brands.
Oct 05, 2009 | Sony KP-53S70 53" Rear Projection...
Sony KP-53S70 projector will not power up, no picture;
you have a bad crytical safety cap.replace C517 value 102k at 2kv.
Sep 19, 2009 | Sony KP-53S70 53" Rear Projection...
KP53S70 Problem with picture. The colors don't overlap anymore. Is there an easy adjustment to get them realigned again?
YOU NEED TWO CONVERGENCE AMPS STK392-570 CHECK THE LAST THREE NUMBERS ON THE ONES IN YOUR SET REPLACE THEM BOTH
Jun 10, 2009 | Sony KP-53S70 53" Rear Projection...
SonyKP-53S70
I will check how many times the led blink when I get home tonight. won't be until after 10:00 Central.
Oct 23, 2008 | Sony KP-53S70 53" Rear Projection...
Sony KP 43T90 Projection TV - use headphone
so u bought red white femail rca cables to mini sterio jack or bigger headphone style make sure tvs menu shows outoput on audio out on if u have option should be all it needs turn tv up after
Oct 06, 2008 | Sony KP-43T90 43" Rear Projection...
Sony Model KP-53s70 (Need a replacement Lenticular/Fresnal screen)
Try here: http://www.tritronicsinc.com/
Or try here, they seem to be able to find hard to find replacement parts, including lenticular screens for Projection TVs:
http://www.tvscreenfinder.com/services
Jul 02, 2008 | Sony KP-53S70 53" Rear Projection...
Sony 53s70 rear projection tv
Hi!! have you tried checking the main plug for it, as well as removing the cables at the back? chances are there are loose wires on it, if you only had it for two months then you still have the warranty for the product call sony's technical support
Apr 26, 2008 | Sony KP-53S70 53" Rear Projection...
There is a blinking light in front of my tv blinks 8times turns off for 4seconds and starts again
Check C514 next to flyback xformer.If shorted,burnt,replace
with part # 1-161-754-00 102K / 3KV capacitor.May also have open
2 amp pico fuse in power supply......T
Oct 25, 2007 | Sony KP-53S70 53" Rear Projection...
Sony KP-53S70 53" Rear Projection Television Logo
186 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
