HP PSC 1210 All-In-One InkJet Printer Logo
Question about HP PSC 1210 All-In-One InkJet Printer
Hp psc 1210 printer turns offs automtically when
Hp psc 1210 printer turns offs automtically when printing command is given [email protected]
Posted by Sharad Shukla on
Anonymous
HOW DO YOU MEAN BY RESET CODE
Posted on Jan 09, 2010
How to get it off print pause on the printer
If you are given print command and that time printer off position no issue, because print command given after on the printer then printer seance any command or printer print the doc.
Thanks,
HP PSC 1210 PRINTER switches off when print command is given. Scanner and copier works fine. unintalled and reintalled several time .problem persists
Shukla,
It seems that the printer drivers are corrupted while the copier and scanner drivers are fine. Disconnect the device from the computer, uninstall the device from Control Panel->Add Remove Programs and reboot.
Once rebooted, reinstall the device drivers from the CD that came with the device. Connect the device and allow Windows to autodetect it and load its drivers. Windows will tell you in the right bottom of the screen "The new hardware is installed and is ready for use".
Start printing.
1helpful
2answers
How to change my HP psc 1210 default to print in black (no color)
this is not possible. I contacted tech support for this, the printer/driver is designed to print in color and HP is not going to change the driver. A real shame, and actually a rip off, but nothing you can do about it.
1helpful
3answers
Unresponsive printer
First off, I will try an uninstallation of the printer
Then reinstall all the drivers and software for the printer.
1helpful
5answers
Printer
send me dirver software hp 1210 all in one inkjet printer
HP PSC 1210 does not print at all
i dought dust would cause that, reboot pc and unplug printer
plug printer back in then turn computer back on, if still doesnt work try a different usb port
Printer is not working
Will the printer print anything at all?
If it prints out anything, liek say open word try to print something out in there, if that works it may be a bug in Gmail.
Also what are you trying to print in Gmail, I can test it on my side aswell, I have a Gmail account.
Thanks,
Cam
Clive
Clive
Ben Johnson
