Question about Acer Aspire 5602WLMI Notebook
Double Clicking on Acer OrbiCam OrbiCam window
Double Clicking on Acer OrbiCam OrbiCam window comes up and says
The Camera is used by another application.
and
Change Server and Try again buttons.
No other server is installed!
Clikcjing on change server makes Camer call-up send clicking sound as if searching
OrbiCam windsow says
wait
and then
Used by other server
Posted by reinelt on
Anonymous
    New Friend:
    Problem Solver:
  • 15 Answers
Ur cam may also used by hackers but possibility of this is very less. open task manager check process if there it is using by any then end that process. if problem not solved reinstall ur cam driver.
Posted on Mar 03, 2010
My orbicam doesn't come on how do i get to that info ? I don't even have an icon for it.
First we will create the new folder where the pictures will be moved to:
1. Click on the Start button.
2. Click on Computer
3. Double-click on the C drive
4. Double-click on Users
5. Double-click on your user name
6. Double-click on Desktop.
7. Once you are in the Desktop, right-click on a blank white area (not on an icon) then select Create > New Folder.
8. Call the folder "Picture Backup" or any other significant name. (Do not close the windows since we will need it later) in step 11
Now we will move the pictures from the old folder to the new one:
9. Click on the START button then click on Pictures
10. Click on one picture and then go to Edit > Select All. This will highlight all the files in this folder.
11. Right-click on one of the selected files then select Cut
12. Go back to the folder we created in step 7 and
13. Right-click and paste the contents we Cut from the Pictures folder.
Now, restart your computer and try the OrbiCam application again. This should allow your OrbiCam application to work again.
Oct 28, 2010 | Acer Aspire 5610 Notebook
Webcam issues
For use with systems including an Acer Orbicam, CrystalEye, or other factory installed camera.
Taking still pictures
  1. Double click the Orbicam Icon to start the program, which will open the main application screen.
  2. Set the configuration choices by clicking on the "gears" icon, which should open an additional window that slides out. Clickthe tabs and select the options for the desired settings. By default, still pictures will be sent to the "Pictures" folder.
  3. Set the resolution for still pictures by pressing the arrow under the main display. A drop down menu should appear with the available resolutions. Larger resolutions will result in larger file sizes.
  4. To take a picture, align the subject in front of the camera so that the display appears in the window as desired. Click Take Photo.
  5. The pictures should appear along the bottom of the application window if the Gallery view is enabled.
Using the camera as a webcam
  1. It is suggested to find a third party application to use this functionality.
May 19, 2010 | Acer Aspire 3610 Notebook
I dont know how to turn camera on
Q: Camera Usage Instructions
A:
Recording video
We cannot support third party application configuration or use.
Feb 18, 2010 | Acer Aspire 5315 15.4-inch Notebook PC
I have toshiba a505, how do i mk my webcam work
A:
Recording video
Feb 18, 2010 | Acer Aspire 5610-4648 Notebook
Acer Orbicam not connected
keep turning it then clicking the camera start up button, it will start again, i have to do this everytime, but not much use when using MSN, though. as it will say the camera is in use, stupid camera and software this is but only solution is to buy a cheap web cam
Sep 24, 2008 | Acer Aspire 5610-4648 Notebook
Acer orbicam - when I try to start up orbicam it says it is being used by another application and that I should close that application and then open oribicam. I have no idea how to find out what...
it is not being used, this is a common fault of the Orbicam, with no answers or newer drivers from Acer, the belo works for me as i have the same problem along with many others.
open up the cam software as normal, then turn your camera to face the back of your notebook, turn it back again and keep clicking the camera start button and eventually it will come on.
Aug 20, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Instructions for use acer aspire5050-5430 notebook orbicam
These are the text-only instructions:
Launching the Acer OrbiCam
To launch the Acer OrbiCam, double-click on the Acer OrbiCam logo in the
desktop.
OR
Click Start > All Programs > Acer > Acer OrbiCam. The Acer OrbiCam capture
window appears.
Changing the Acer OrbiCam settings
Resolution
To change the capture resolution, click the displayed resolution at the bottom
right corner of the capture window, then select the desired resolution.
Note: Setting the camera resolution to 640 x 480 or larger does
not change the capture window size.
33
English
Options
Click Options to display the Window, Preview, and Folder tabs. Use the options
to change the capture window size, preview settings, and the folder for
captured photos or videos.
Camera Settings
Basic settings
Click the Camera Settings icon on the bottom right corner of the capture
display, then select Camera Settings from the pop-up menu. You can adjust the
Video, Audio, and Zoom/Face tracking options from this window.
34
English
Capture settings
From the Camera Settings window, click the Driver Settings button. The
Properties window appears.
Device Settings allows you to change the camera brightness, contrast, hue,
saturation, sharpness, etc.
Advanced Settings allows you to activate gain control, implement image mirror,
select image enhancements and anti-flicker settings, and turn on/off the camera
indicator.
Zoom/Face Track Settings allows you to adjust the zoom level and turn the
face-tracking feature on or off.
Capturing photos/videos
To capture a photo or a video clip, rotate the Acer OrbiCam to get the desired
angle, then click the Take a Picture or Record a Video button. The Windows
Picture and Fax Viewer or the Windows Media Player automatically launches to
display/play a preview of the photo/video clip.
Note: By default, all photos and videos are saved in the My
Pictures and My Videos folder.
Using the Acer OrbiCam as webcam
The Acer OrbiCam is automatically selected as the capture device of any Instant
Messenger (IM) application. To use the Acer OrbiCam as a webcam, open the IM
service, then select the video/webcam feature. You can now broadcast from
your location to an IM partner anywhere in the world.
Jun 10, 2008 | Acer Aspire 5100 Notebook
Acer orbicam
There are two software entities involved – the camera Drivers and the OrbiCam application itself – and BOTH need replacing/updating to fix this problem.
The new driver and a new version of webcam application (below) seem to fix the issue.
The correct files to download are:
Acer Orbicam driver (Bison)
Acer Orbicam Bison utility 1.0.0.13
These can be found here under the MS Windows Vista drop down menu:
http://support.acer-euro.com/drivers/notebook/as_9300.html
In order to fix the problem, you must download and install them both to make the Orbicam work correctly.
FOLLOW THE INSTRUCTIONS BELOW IN THE SAME ORDER:
1. remove the installed OrbiCam application and reboot if required;
2. install the new driver (preferably with the “driver update” wizard from Device Manager)
3. update the Orbicam application 1.0.0.13
After this, the webcam should function properly, even if the original Orbicam icon disappears.
To check everything is working OK run LiveCa07.exe or BisonM07.exe that are located in the c:\windows\bisonxxx\ folder or simply run Messenger
Feb 19, 2008 | Acer Aspire 5101WLMi Notebook
Aspire 5610-2762 Orbicam not working
** Note ** When the My Pictures or Pictures folder gets full, camera will not work - Cut and Paste all pictures in that folder to another folder and restart Orbicam program.
If that does not work then do this:
Start - Programs - look for Acer Empowering Technology then Acer E-Recovery - The look at the bottom and you will "Backup", "Burn disk" and Restore" choose Restore - choose Apps and Drivers at the bottom of Restore tab (it will say extracting) - once extracted - click Install - click Vista or (XP) on the left - click Drivers - click Camera or CCD - on the right side of the screen, click a phrase that has something like "Install now", follow on screen instructions.
Dec 18, 2007 | Acer Aspire 5610-4648 Notebook
My orbicam
The symptoms
The symptoms arise when a user double clicks on Acer Orbicam (Desktop icon), and Vista displays the following message: “Acer Orbicam application has stopped working” and needs to be shut down.
First of all, your webcam is still working, the device does not have problems. You can check this quite easily by opening Messenger -> Tools -> Webcam Settings.
Another way is to check the folder:
C:\windows\BisonCam\
There you will find the application “LiveCam.exe”. Run this to check that the webcam device is working fine.
If you don’t have the “BisonCam” folder, this means that your webcam is a different model; I don’t yet have a complete list of all the devices and their relative folders but all notebooks and webcams have some folder so if you look hard enough you’ll find yours.
The problem
There appear to be two factors that can create this problem:
1] The Orbicam application needs the correct orbicam driver to work correctly;
Windows Vista has its own internal driver to install the device, naming it “Acer Orbicam” (great Windows!!) but in this way the application cannot find the correct driver, so Vista returns the error message.
2] If some pictures are present inside “My Pictures” folders, the Orbicam application will fail to start. It seems to be a Vista issue and still needs to be fully clarified.
The problem seems to have been caused by the Vista Upgrade software, which causes the OrbiCam application on certain models to malfunction. However, as explained above, the OrbiCam camera works fine, the software just can’t control it correctly after the upgrade.
Another issue that has added to the confusion here is that there are “more than ten” different types of OrbiCams installed on Acer notebooks. Again as mentioned above Windows Vista has its own internal driver to install the device, and simply calls it “Acer Orbicam” which makes distinguishing the correct driver from wrong one an almost impossible task. If you replace your driver with the wrong one, the application cannot find the correct driver and you get the now famous error message.
Lastly, the problem is restricted to Vista-ready notebooks and NOT native Vista notebooks. By that I mean the problem does not exist with the new Gemstone and TravelMate ProFile models as these were designed specifically to run under Vista.
I know this is no consolation to users with this problem but I just wanted to reassure readers that this issue is not endemic to all Acer notebooks.
Solutions
Currently only 2 notebooks have complete solutions available online. This is because - so far - they are the only “problems” Acer support technicians in Taiwan have been able to fully replicate, analyse and repair.
These “fixes” are not general solutions and ARE NOT OK FOR ALL NOTEBOOKS. This explains why some readers have been getting error messages with the new drivers/applications. The new drivers and applications can be found at the following addresses:
Aspire 9300 at the following link:
Aspire 5570 at the following link:
http://support.acer-euro.com/drivers/notebook/as_5570.html
If your notebook is not one of the two above, read on:
For all notebooks with Acer Orbicam the repair procedure is the same:
1] identify the specific webcam device you have inside your notebook
2] get the hardware description (hardware id) of your notebook’s webcam
3] get the full serial number of your notebook (long alphanumeric code in the bottom side)
4] send this information to your local support centre who can then walk you through the procedure for your specific notebook.
All steps are important because only with the above information can Acer correctly identify the right driver and application for your notebook. Simply sending “Acer Orbicam” as the description, does not help because all the different webcams Acer installed are called “Acer Orbicam” (again, thanks Windows)…
So how do you identify the right one ?
How to get the webcam device information:
Go to “Control Panel”, switch to “Classic View” (the support team still find this way easier and better to work with than the default one) and double click on the “System” icon; to the right you will find Tasks list and below “Device Manager”, click on this.
Now you have the full list of devices of your notebook, look for “Imaging Devices” and double click on this. Here you will find the Acer Orbicam.
542506847_38185ec1b4_o.jpg Double click on “Acer Orbicam” and the Acer Orbicam Properties window appears. There are three tabs : General, Driver, Details
542397216_657b57f5d0_o.jpg Click on “Driver” tab, the important information listed here is:
“Driver Provider” and “Driver Version”
542506947_d280ed5924_o.jpg Copy this info onto a word / txt file or take a screenshot of this window. Just make sure you write down this information. Then click on “Details” tab
542506971_0b3e8f0f00_o.jpg Under “Property” you have a scrolling list, click on it and open the drop down menu.
542507017_6f244cf125_o.jpg On the drop down menu look for “Hardware Ids”. Click on this.
In the Value box, you should find something similar to:
USB\VID_5986&PID_0102&REV_0100&MI_00
USB\VID_5986&PID_0102&MI_00
542397338_1d8c1d1f3a_o.jpg As before, copy these two lines or make a “screenshot” of the window
At the end of all this you will have:
Your Notebook’s Serial Number
The OrbiCam Driver Provider
The OrbiCam Driver Version
The OrbiCam Hardware IDs
Send all of this information to Acer with your support request/telephone call. This should cut down the time it takes them to get you back up and running.
Good Luck, should get your cam going again/Please dont for get to Vote, Thank You.
Dec 15, 2007 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5602WLMI Notebook Logo
229 people viewed this question
Lee Hodgson
Lee Hodgson
Gustavo Ortiz
Gustavo Ortiz
Michael Thomas
Michael Thomas
