Question about Samsung LN-T4665F 46 in. LCD Television
Samsung 40 '' lcd just clicks but wont turn on
Posted by haggisking on
Anonymous
    New Friend:
  • 16 Answers
Most likely failed capacitors in the power supply. I am currently having the same problem with my 26 month old LN46A750. Samsung has agreed to fix this as an out of warranty "courtesy repair".
http://www.thebuzzmedia.com/samsung-tv-capacitor-clicking-issue-and-free-repair/
http://www.avsforum.com/avs-vb/showthread.php?t=1198409
Posted on Aug 21, 2010
My Samsung LCD wont turn on
samsung will fix it free of charge .i had the same fault with mine it is 3-4 years old .phoned samsung and they fixed it for free
May 11, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Samsung tv wont turn on stand by button just keeps
hi,
your lcd tv got to replace the ip board (power board) the capacitor has already exhusted.
Apr 19, 2010 | Samsung LE40M91B 40 in. LCD TV
My tv will not turn on, it just clicks but doesnt
You will need to have the power supply board replaced. This is a common problem and Samsung has re-designed the new boards so this will not happen again. You can call 1-800-samsung for the nearest authorizd service center.
Feb 26, 2010 | Samsung LN-R409D 40 in. LCD Television
Samsung 40" tv not coming on
I would check out the power supply module for bad caps with bulging tops. Check DC voltages at the output connectors, you should have 5, 12, 24V.
Jan 08, 2010 | Samsung LE40R74BDX 40 in. LCD Television
Tv clicks but wont turn on
power supply board has probably failed, common problem. call1-800-samsung for nearest service center.
Nov 25, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
It inly clicks and wont turn on
you have a bad cap or caps in your power board the can like device will have a puffed up top the value is written on the side replace it or them and your good
Nov 20, 2009 | Samsung LCD-TV LE40S81B 40 in. HD-Ready...
Samsung lnt4042hx/xaa 40in lcd tv wont turn on
I concur with Lightnbaby.... had same problem... my TV LNT4042HX/XAA took 10 min to start sometimes... the capacitors on the power supply board had bubbles on top 4 of them all 10/1000Uf. Samsung wanted to charge $220+ to have a guy come out and fix. J&J parts (samsung vendor) wanted $108 for a new board. I replaced the 4 capacitors for $4.68 and the TV works fine now!!!!!
Apr 14, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
Samsung LN-T4665F 46 in. LCD Television Logo
184 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Ekse
