Question about iRiver T30 MP3 Player
My T30 is freezing up and I can't delete files nor download to the T3 the T30 window says USB connect but it does not respond to 'comands' from PC
  • 1,234 Answers
Hello ,
i'm glad to help you
You Can Download Free MP3 From Youtube By This Site : video2mp3.net
If you didn't found Your Favorite Music In Youtube Try These Sites : Beemp3.com or 4shared.com
Posted on Aug 30, 2010
Delete autorun inf virus 4gb
If you have a autorun.inf virus on your memory card/USB stick the anti virus software on your PC may not allow access in order to stop it from spreading.
First you need to disable autorun feature on Windows operating system :
Follow steps in link :
http://www.redmondpie.com/how-to-disable-autorun-autoplay-in-windows-7-and-windows-8/
After disabling the feature you will have access to your memory card/USB stick. The next step is to delete autorun.inf virus file hidden on your memory card/USB stick. But first you need to make the hidden virus file visible.
Follow steps in link to show hidden system files :
http://www.bleepingcomputer.com/tutorials/show-hidden-files-in-windows-7/
Now navigate to your memory card/USB stick you should see the autorun.inf file - DELETE IT.
(If it doesnt allow you to delete it - restart the PC in safe mode by pressing F8 on start up and choosing safe mode and try again)
Back up your files on the memory stick/USB stick to your PC and to make sure the virus is gone from the memory stick/USB format it using your PC.
Dont to forget re-hide your system files to prevent accidental deletion.
Oct 15, 2013 | SanDisk 1GB microSD Memory Card
Tip
Easy way to pushfix iphone, wifi,youtube problem
download these file from google, pushfix.deb file, and total comander, T-PoT.wfx,
i tried many ways here is the clear solution, at first srep you must download total comander from google, install the total comander after installation you must go to configuration and select plugins and you must configur (.wfx) and then you must add the t-pot file and click ok. here you finished the instalation
now connect the iphone to your pc and open total comander and select neighborhood>t-pot>private>var>root past the pushfix file here you can drag and drop the file.
in iphone you must go to cydia and search for ifile and install the file after install go to ifile go to var and select root there you can see the pushfix select the file and install and reboot your device and the problem of youtube will be fixed
on Jul 14, 2010 | Cell Phones
I have an acer one netbook /notebook---- computer freezes....worsenes w/tiime....sometimes it boots to windows then freezes,in safe mode .......still freezes....
CorruptedSystem Files
Your computer freezes due to corruptedsystem files. System files corruption is one of the most responsible causes forcrashing the entire computer. Deleting or moving the system files may crashyour computer.
1. Insert the Microsoft Windows Installation CD ROM.
2. Click Start ' Run.
3. Type SFC/ ScanNow and press ENTER.
4. Follow the instructions on your screen.
Corrupted Registry
System registry corruption leads to runtime errors and your computer crashes.Windows Registry is very complex and not easy to repair manually. Hence, athird-party Registry Cleaner and PC Optimizer software is recommended.
1. Download a Registry Cleaner and PC Optimizer software such as Reginout.
2. Click Registry Cleaner tab.
3. Click Start Scan.
4. The registry scan will start. Wait till it is finished.
5. As per the results, click Fix Now button to start repairing you registry.
Often good registry cleaners include built-in Backup & Restore centre thatlets you recover from an unforeseen situation by simply restoring the state ofyour registry.
Faulty RAM
Your computer freezes due to problemswith the computer memory. A faulty RAM may result in Blue Screen of Death(BSOD).
In such a case, remove the existing RAM and clean it using a soft cloth. Then,connect it again. The problem may not persist..
Incomplete Installations
Your computer freezes because of a previously failed or incompleteinstallation. An incomplete or failed installation creates junk registryentries and thereby system crashing problem.
Repair the registry entries created by a failed setup and delete the files thatstill remain on your hard disk. Delete the contents of C:\Windows\Temp folder.
Disk Space Allocated by Unnecessary Files
Your computer freezes if the operating system has no adequate free disk spaceto perform its operations. Temporary files, temporary internet files, logfiles, browser cache and other files may occupy a large amount of your diskspace and thus generating runtime errors that crashes your system.
Using Disk Cleaner, delete the junk files from your hard disk. The steps are asbelow:
1. Click Start ' All Programs ' Accessories ' System Tools ' Disk CleanUp.
2. Follow the instructions on your screen
Dec 02, 2010 | Acer Aspire One PC Notebook
I bought a used T30 so I don't have the instructions. I can't get my arrow pad to work. I can move the arrow but when I click on something I have to use my mouse?? Is there a way to activate so I can...
debiplow401 what if I give you the instructions?
ThinkPad T30 Setup Guide.
(How to;
1) Set up your computer
2) Turn on the system
3) Use the TrackPoint pointing device
4) Volume button controls
5) Access ThinkPad
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-42266
Click on the first file listed -
t30engsq 62p9239.pdf.............English - Setup Guide for ThinkPad T30
This is a PDF file. Takes a few seconds after you click on the file name to see the first page. Also takes additional time to fully download. Suggest letting the file fully download before looking through it, or saving a copy.
If you are aware of the following please disregard;
1) The box to the right of the blue Down Arrow is the page number box.
If you know the page number you wish to go to, you can;
A) Put your mouse cursor in the box, Left-click once
B) Type the page number
C) Press the Enter key
Much faster than using the Down Arrow.
The + sign in the top header is the Zoom In icon.
The - sign is the Zoom Out icon.
Most of the time the file will be downloaded in a too large view for readily viewing.
To save a copy:
You can save a copy to a CD disk.
This way you can delete it from your computer, and save Harddrive space, and have the file anytime you wish.
Left-click on the Floppy Disk icon.
The Floppy Disk icon is in the top header, and is the second icon from the left.
If you hover your mouse cursor over the Floppy Disk icon, it will briefly reveal,
"Click to save this file to your computer or another location"
After you click on the Floppy Disk icon a small window will come up.
Save a copy...
At the top of the Save a copy window you will see a box with - Save in: to the left.
In the box is stated where the file will download to.
I would put the file in My Documents.
Click on the blue Down Arrow to the right of the box, then click on My Documents in the list.
Down at the bottom of the Save a copy window is the File name: box.
You will see - t30ensq_62p9239.pdf in the box.
You can add to this file name to make it easier for you to find.
Put your mouse cursor in the box right after the f in .pdf
Left-click twice.
Type ThinkPad T30 Setup Guide.
Now go to the bottom of the Save a copy window, and click on Save.
To find, and open the file:
Click on Start> Double-click on My Documents > Click on the file name
You may wish to have this also,
ThinkPad T30 Service and Troubleshooting Guide -
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-42265
Click on the 4th file down,
T30engstq 67p4720.pdf.............English - Service and Troubleshooting Guide for T30
This is a PDF file.
You can save this to CD disk also.
Oct 22, 2010 | IBM ThinkPad T30 2366 Notebook
I lost my recovery Cd. Where can I buy it?
If you cannot purchase a Recovery CD from IBM/Lenovo then you can download the device drivers from their WEB support site.
To restore your T30 back to the original Windows beg borrow etc a Windows installation CD. This CD must match the Windows version on the label on the bottom of your T30, it also displays the Product Code and this is used to install Windows on your T30.
Follow these instruction to download and install the T30's device drivers.
The same model ThinkPad can have different types of network, video and audio drivers and unless you know exactly which one is installed in your ThinkPad, you need to download all the drivers and install each driver until you find the right driver.
When you download the drivers, write down the device driver and it’s file name so you have a record of which driver you are installing and which directory the unzipped files are located on your hard drive.
Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows XP or Vista device drivers for your model computer, Use this link: -
http://www-307.ibm.com/pc/support/site.wss/product.do?template=%2Fproductselection%2Flandingpages%2FbrowseByProductLandingPage.vm&sitestyle=lenovo&brandind=10&validate=true
You can download the various drivers and then you click on and run the various driver files, they will then unzip and expand into a sub folder on C:\drivers Then install the various drivers from this folder (run the set-up file).
Jun 19, 2010 | IBM ThinkPad T30 2366 Notebook
Drive c nearly full, what do i do
1) Log onto Filehippo.com download, install and run Ccleaner. Its free and will clean all the web related garbage off you computer you didn't know was there.
It can also be used to un-install all those programmes you no longer use.
2) Burn your music (mp3) files to DVD or CD. Then delete them from you HDD.
3) Burn all your Photo's to DVD or CD then delete them.
4) Burn all the Documents you wish to keep to CD/DVD then delete them.
May 16, 2010 | Acer Aspire 5610 Notebook
My desktop freezes when im running a program most of the time in my windows 7. there is no blue screen or any error. the pc just stops responding the mouse doesnt move. i dont have a choice but to restart...
Windows 7 is a slightly heavy (lighter than vista though) operating system (OS),
so it tends to freeze on computers with low specifications.
You can free up some disk space by deleting the old windows files, thats if you had an OS before Windows 7 previously installed, you can also delete unnecessary files that you dont need.
If your pc has low specs, and you were originally using Windows XP, the best solution would be to go back to Windows XP
Dec 31, 2009 | Intel Motherboard
IBM T30 screen ramdomly goes blank and computer freezes.
Reset your bios settings to "Bios defaults", then disable power management.
In Windows, go to device manager and try to detect new hardware. Follows screen instructions.
Mar 27, 2009 | IBM ThinkPad T30 2366 Notebook
FM 2009 continually freezing/message says Windows not responding.
Steps
1)Optimize the browser by clicking on Tools>Options and delete temporary files in Internet Explorer
2)Check any antivirus installed and uninstall it.
3)Check the service pack and if found service pack 3 uninstall it from add/remove programmes under control panel
Dec 29, 2008 | Microsoft Windows XP Professional With...
Cannot transfer files
go to http://www.iriver.com/support/down_view.asp?searchProductIdx=73&searchCategoryIdx=1&searchString=new+firmware&page=1&idx=844&tmpSearchProductIdx=&tmpSearchCategoryIdx=&tmpSearchString=
download the updater. unzip the file and run the installation program. after you have install the iriver firmware updater, run the program. it will automatically detect what you need. follow the instructions. if the updater stops at 50% don't worry. wait bout a min or 2 then unplug your T30 and it will update by itself
Dec 07, 2007 | iRiver T30 MP3 Player
iRiver T30 MP3 Player Logo
91 people viewed this question
Top iRiver Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Ekse
Zaid Anarwala
Zaid Anarwala
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
