Computers & Internet Logo
Anonymous Posted on Jan 09, 2010
How to connect my dell dial up modum to lap top
How to connect my dell dial up modum to connect to my lap top for internet access
  • Anonymous Jan 15, 2010
    Thanks for the assistance however I must have not explained it well enough I do have usb to serial adapter it shows in the device manager as SBP2 IEEE 1394 Devices and shows compliant with no issues. When I try to connect with usb to serial adapter I get error message 633 "The modem (or other connected device) is already in use or not configured properly. I would appreiciate any other suggestions you may have I have Windows Vista IE7 if that matters. Thank you again :)
Edward
Level 2:
New Friend:
  • Expert 104 Answers
  • Posted on Jan 09, 2010
 Edward
Expert
Level 2:
New Friend:
Answers
104
Questions
0
Helped
18817
Points
286
Your dial up modem needs to be ab external modem.
You can not use an internal modem from another machine unless you create a network and share your connection.
If you have an external modem then connect the modem to the available port on your laptop and let plug and play take over. If you do not have a port on your laptop and you modem has a serial port you will need a usb to serial adapter which you can get at Radio Shack.
Testimonial: "Very quick response and very helpful with suggestions!! "
  •  Edward
    Edward Jan 10, 2010
    Don't forget to rate my solution!
I did not get a windows disk-I am trying to install total fax vs
If you are not using your modem to connect to internet or something else you can get by... Follow the steps...
Right click on "my Computer" click on "properties" click on "Hardware" tab click on "device manager" Find your modem in the list and click on it once. On the menu bar at the top click on "action" and select "disable" That should stop your computer looking for drivers for your modem.
If it doesn't work, it may be your web browser. Check your internet connection settings and make sure you browser is not trying to use dial up connection. Go to your internet explorer properties click on connection tab and check "never dial" option for dial up connection. Good Luck :)
2answers
CANNOT FIND THE MODEM FOR MY DIAL UP CONNECTION
I have a Dell Latitude too, my modem is on the back and has a tiny phone handset icon below it.
I was given a think pad 2647 and I can't get on the internet.
It may not detect it automatically. You will need to configure your dial up modem if you are trying to connect to the internet that way. Go into the network connections and go through the wizard there. It should ask you for the telephone number to dial for internet access so have that handy. If you don't get that box, you went to the wrong area.
Wireless in dell lap top
It has something to do with the use of your wireless connection especially if it is an open access service. It is possible that there are many users in your area and you have to share the bandwidth of the wireless connection that reduce the efficiency of your laptop. Try finding another source where only few people connect.
Cannot connect to the internet
open internet explorer, go to tools, internet options, then the connections tab and make sure ' never dial a connection' is ticked, assuming you had a dial up connection before using the router on this pc or if you briefly used it.
2answers
New lap top
Open a web browser and type http://192.168.0.1 in the address bar.
Enter admin for the username and no password to get into setup.
Setup your account.
I have on-line service and I purchased your router to get on-line service to a second computer six feet away from me. All of your illistrations show only one modum, one router, and one computer. Do you...
u need to have network card to access the other computer,and also sys 1(where modem is connected) which acts as a server should be always on in order other system to get access to net,and in the 2nd sys open Internet Explore go to Tools>internet options>Connections> in LAN settings give the IP address range..That would work fine
Top Ultra Computers & Internet Experts
john h
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
Are you an Ultra Computer and Internet Expert? Answer questions, earn points and help others
