Question about Hitachi 43FDX01B TV
Color has changed to green tint
We have the Hitachi 43FDX01B projection TV, all of a sudden we now have a constant green tint
  • Anonymous Jan 10, 2010
    It worked , Thanks.
  • Robert May 11, 2010
    If you are connecting to the TV using a component cable check all of the plugs and make sure they are all tight sometimes this can cause the picture to do this. Good Luck...
AMJAD HUSSAIN
  • Hitachi Master
  • 586 Answers
    According to the system the problem in your projection is convergence and the solution is to replace the IC STK's.The part Number is CZ01341. Change the IC STK both and your TV work fine again.And for parts please see the link below.
http://jr.partsearch.com/Model/Hitachi+Ltd/Hitachi/43FDX01B.aspx?SearchTerm=True
   Thanks.
Posted on Jan 10, 2010
Green tint
Go to a channel that is in black and white and turn color all the way off.
Screen should be a black and white or gray color.
If green there is a fairly easy way to adjust--let me know what you find and I will tell you how to attempt the adjustments.
Hitachi Projection Color TV 43FWX20B - COLOR OFF
Check all cables,replaced all cables if more than couple years old.After that the same,ur tv have one dead color gun,require service.
I have a hitachi 43FDX10B ultrascand HD rear
well it seems to me that you need to call the manufacturer to see how to reset the pixels for that tv. it seems someone has taking a magnet or something like that to the tv screen
I have a Hitachi Ultra Scan HD TV model #43FDX01B - Green line
Hitachi Projection TV Repair Kit for one or more of the following symptoms
This might not be your model but you should contact them to see if the have the parts I know they list the manual
2helpful
2answers
Convergence on Hitachi 43fdx01B not working
ik04,ik05:stk392-110(replaced with:stk392-150)resistors:rk46,54:1,5ohm.,rk42,50:2,2ohm.,rk58:3,3ohm.,rk62:1,8ohm..try make order in "MCMelectronics".,partstore.,bdent.
Hitachi 43FDX01B color
sounds like bad convergence Ic's--set uses two of them, common on many projection tvs.
2answers
HITACHI ultrascan hd tv....
toni, you`ll need a tv tech for this problem, spark gaps need to be cleaned, crt sockets need to be cleaned and crt pins on all 3 crt`s need to be sanded, this is a common issue with this model set, good luck, BMW Rider
Hitachi 52 projection tv
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Bad picture
convergance ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Hitachi 43FDX01B TV Logo
Top Hitachi Televison & Video Experts
Ekse
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
