Question about Refrigerators
Stop working. stop running. where is the reset button? where is the overload?
  • Donald  Rowan
    Donald Rowan May 11, 2010
    you will need your model number for help. and as much information you can provide. like : do the interier lights come on ? do you here the fan in the freezer. is this a top mount or side by side. what is the name brand ? Do you here any funny noises ? Do you see any frost in the freezer ? Help us, Help you :)
  • maria jessie Dec 16, 2012
    the model is GLHS37EHSB6 and it stopped working the fan is still running but the refrierator and freezer will not work, its not getting cool at all. what can i do to restart it or just fix it??
    Novelist:
  • 101 Answers
It will be very diffilcult for even the most experienced technician to troubleshoot your refirgerator with so little information. No make and model number, no infor on how old it is...therefore start with the basics:
Verify it has power (does the interior light(s) come on?
If so, most refrigerators DO NOT have a reset button. The motor overloads reset when they cool off. If your unit has power and will not start after left alone (unplugged) for a few hours, then either the thermostat controls (most likely), a part of the thermostat controls (some controls use mutilple sensors and control relays), the overload on the compressor is bad or the compressor itself is bad. If the condenser fan runs but the compressor does not...I would suspect a problem with the compressor or it's electricals. If nothing starts except lights...I would suspect the temperature control. Good-luck.
Posted on Jan 09, 2010
Anonymous
SOURCE:
1500 electric snow thrower just stopped working
motor humming -- replace the start/run capacitor
no noise at all --- press the thermal overload button or replace the thermal overload switch
Mar 16, 2018 | Electric Garden
QRS 25 air compressor will not start unless I push the reset button need to know where the reset button is
How do you know it will run if you reset the reset button? You could have a problem with the coil of the starter, pressure switch not closing and/ or overload issues. The reset is usually on the overload block. To check the coil you need a volt meter where you can measure in ohms or resistance. Remove both wires on the coil with power off !!!!!! and measure across those two terminals. If it is showing open then you have a bad coil. To check the pressure switch to the same thing across the motor and line terminal. If open with 0 psi in tank then pressure switch is bad. Last thing to check is overload block, there are normally a 95 and 96 terminal. Check for continuity across those two terminals (while power is off !!!!!). If open and the reset button is pushed then the overload block is defective.
Jul 26, 2014 | Air Tools & Compressors
Compressor stops working is there any reset button
no reset button. could be defrost timer, main board or compressor overload. probably best to call for service
Jan 08, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
The refrigerator worked, but when unpluged and moved the compressor no longer runs. Is there a reset button on them?
no there is reset,but,the ptc overload relay plugged into the compressor is bad,purchase a new replacement ptc overload relay and plug in into the compressor and it will again cool properly
Apr 12, 2011 | Kenmore Side by Side Refrigerator
We have a 100 ton press electric motor an a hydraulic pump.You have to hold in on the reset to make motor run.
The overload switch may have failed. Does the motor stop if you let go of the reset? If the motor (single phase) has a capacitor start, the capacitor may have failed partially which will cause overload because the motor just sits and hums without turning. If this is a three-phase motor, the overload button should shut off the motor starter which directly removes power to the motor. Don't jury-rig a switch to bypass the problem. Hope this helps!
Dec 22, 2010 | Garden
Kenmore 116.23513301
If the motor on the power brush is running the belt is bad, if the motor on the power brush only runs when you push the overload, the overload is bad.
Sep 14, 2009 | Kenmore 22812 Bagged Canister Vacuum
Sewing machine motor will not run after attempting
Overload Viking:
The machine has a built in overload protector, if your needle can’t penetrate, it may stop the machine from working for a few minutes. Just wait it will reset automatically. Then, try a Sharp needle (denim needle is ideal) and be sure to Never Never reverse sew on heavy fabric, your needle will bend and hit the needle plate, use the FIX button for knotting (it really does work).
Mar 15, 2009 | Husqvarna Designer I
Fan and light no longer turn on
possibly the thermal overload sensor failed internally? as indicated in the instructions there is a overload sensor and thay will typically fail in others appliances.
Oct 30, 2008 | Reiker RRC120004 Brushed Steel Ceiling Fan
Maytag SAV 205 DAWW
Look for a self resetting overload on the motor. many motors have an overload that pops a little red button out and waits for a push to reset. Other overloads will reset automatically because they are hard to access for pushing a button. If there is an overload resulting in a shutdown you will have to determine the cause. I have found motors in washers completely ingulfed in dust and lint (from the adjacent dryer) and not being allowed to dissipate heat. Sometimes a thorough cleaning is all that it needs to run cool and efficiently.
Jan 18, 2008 | Maytag Legacy Top Load Washer
Refrigerators Logo
172 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
