Question about LG LRFD25850 French Door Refrigerator
We recently moved and hooked up the water/ice. It
We recently moved and hooked up the water/ice. It worked for about a month and suddenly stopped making ice however the water dispenser works find...
Posted by david_s_palm on
Mike
  • 166 Answers
Replace the icemaker.
If the ice maker mold is tan or silver they are defective.
Moisture gets into the head unit and jams the gears.
You can remove the icemaker and let it dethaw for a day and it might start working for awhile.
The new redesigned icemakers are brown in color.
Hopefully the switch on the side of the I/M is turned on..
Posted on Jan 09, 2010
[LG Refregerator] Model LFX25961AL water does not dispense and ice is not being made
Make sure the wire guide that pulls up when ice is at full capacity is not accidentally pulled up. (this is above the ice bin in the freezer). Pull back down and should make ice.
Dec 17, 2013 | Refrigerators
Water dispenser ice maker
If you check the backside of your refrigerator...
There are TWO (2) different electric water-valves...
A generic WHIRLPOOL part number = wr57x10032
(typically you can hear the "THUMP" when the are working...
WATCH this attached video...
http://www.appliancepartspros.com/ge-water-inlet-valve-wr57x10032-ap3192626.html
Hope this is helpful...
Carnac the Magnificent
Dec 07, 2017 | General Electric GSH25JSXSS Stainless...
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
Maytag model MSD2756GE ice maker. Water not getting to ice maker.
Why was there a need to increase the freezer temperature? Are you having temperature problems as well? If so, your ice maker has a built-in thermostat that, unless and until it is satisfied, will not cycle, thereby, making no ice. If temperature seems ok, and the buzzing is only occasional, then that buzzing is most likely the solenoid valve being energized but not passing water. This is a dual solenoid valve (one supplies the ice maker and the other supplies the dispenser) located at the bottom rear of the refrigerator.
Aug 22, 2009 | Refrigerators
Water dispenser suddenly stoped working. Ice dispenser working
check the water line fron filter that continues on to water dispfrom icemaker, also a bad water disp solenoid or no pwr to water valve disp solenoid could be a problem,when you try to disp water can you hear a click from the solenoid operating to let water out?
Aug 16, 2009 | Frigidaire FRS23KF7AB Side by Side...
My water dispenser suddenly has stopped working.
Yes, it could be the water filter. Also check to make sure the water is turned on and that any lines to the refrigerator aren't kinked or crushed somewhere. It's also possible that you will not be making any ice as well if your appliance has an ice maker
Apr 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker & water dispenser won't work
I recently found out that the water supply lines are coiled up inside behind the frige on the refrigerator side moving the unit will cause those coiled up lines to shift to the freezer side of the unit, causing a freeze up,take the cardboard lower back off and move those lines further away from the freezer side of the unit, as one of those coiled up lines are to chill the water for the dispenser and the other is supply for the icemaker, this should fix your problem, becareful not to move them too far away from the freezer side as they are meant to chill the water for the dispenser
Jan 16, 2009 | Frigidaire FRS266ZDSB Side by Side...
GE ESS25XGMC WW Side by Side
its possible that your water tank has frozen up, try turning the refrig off and leave the doors open for about 10-15 mins and try it again. if that works just reset temp controls a little lower..
Dec 15, 2007 | GE GSH25JFR Side by Side Refrigerator
Galaxy Side by Side Refrigerator water dispenser
Check the water valve in back of refrigerator and make sure it is working ok
Nov 14, 2007 | GALAXY Microsystems 25.4 cu. ft....
LG LRFD25850 French Door Refrigerator Logo
141 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
