You should look into Youtube for a vid of dissassembly and reassembly. Youtube is a wonderful tool as techs love to teach.
Also, typically, the entire upper structure folds flat onto the walk belt for easy storage.
Here is a link to the Owners manuel. It will show you assembly, so you can simply work in reverse.
Looks like it may be easier to remove the feet once you have it folded.
please LUBE the deck belt+rollers bearing. see the video attached. If the problem persist TIME to replace the old deck belt board. This happen because the lack of maintenance schedule in LUBE. God bless you
note:forget it the LEDS troubleshooting, you must see the functions ONLY when there are electronic problem with the electronic board+sensor
Try it with some little Inyection of 50% of Oxigened Water +50% ethilic Alcohol(100%) for to clean the contacts or pad for the buttons.
Wait for 15 minutes.
An try it again. Now if doesnot work go to the 2 Step.
2) You must open the cover, and look for the rely for to clean it contacts, in the same ways.The rely is the element for to swith off -and on the motor for Theadmill.
If u r seeing the increasing variation takeing effect on the panel but the speed does not increase in real, then there is nothing wrong with the push button for sure.
what it could be is ,
1. Your motor is getting overheat quickly and does not accept the higher speed commands.
2. it could be a belt slip also (do u hear any extra noice / vibration when u increase speed)
3. next time, pls unplugg the unit for atleast 4 hrs and when u start after that increse the speed very next moment and see if it works. if it does increase this way then it is time take look first on the belt ans then check the motor.
It is trying to its starting point I would suggest is to unplug the unit open the motor shroud unit. The shroud it has a mini manual this should have a calibration instructions that can be done and also upper electronics self test to see if the processor is functioning properly. It should give a better idea which to head. You can call Icon Fitness@ 1-800999-3756
It sounds like it's in calibration mode and you need to let it go all the way up and then down and set itself. If you have done that and it keeps going into that mode then you probably pulled or moved some wiring while moving it.
