Question about Eddie Bauer Musical Rocking Bassinet 10330WOW Crib
I need the bottom skirt and board for the bassinet.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 109 Answers
You can order parts for your Eddie Bauer Bassinet by contacting Dorel Juvenile Group (the parent company of Eddie Bauer baby products)
You can contact them
via email: [email protected]
via fax: 800-207-8121
via phone: 800-544-1108 M-Th 7:00am-6:00pm and F 7:00am-4:00pm EST.
Posted on Jan 11, 2010
Anonymous
SOURCE:
Skirt lining on delta bassinet is riveted on. How to remove rivets to wash skirt
those are not removable unless you want to drill them out.
Feb 06, 2017 | Delta Baby Gear
Do u have video to show how skirt goes back on
NO--but if you go google and type in ---fitting of skirt to bassinet-- you may find a u-tube video
Aug 27, 2016 | Baby Gear
How to put bassinet cover back on
It's easy. Hold the main skirt fabric and drop the pressboard support into the bottom with the feet/nubs down away from the inside. Now the metal frame drops in and next slide the hinged U supports outward. This raises the edges and gives height to the bassinet. The U supports either lock under a plastic clasp on the pressboard or sit into holes on the board. Now button down all the buttons around the interior or zip the zipper closed. Set it back on the frame and snap the bassinet to frame snaps on. Add the hood and baby's new, clean bed is ready for a lullaby. Good luck and you should be able to download a PDF version of the instructions from the maker. Just go to their site and search.
Aug 21, 2012 | Delta Luv Baby Gear
Dont know how to remove the bedding from the bassinet to wash
Which part of the bedding is soiled and needs to be washed?
There should be a flat sheet that covers the mattress pad, an optional top sheet, a comforter, a dust ruffle, pillow sham and a decorative cover for the hooded area.
Remove the comforter & top sheet & set them aside. Pick up the mattress inside the bassinet, remove the flat sheet on it and put that with the other items to wash. Leave the mattress pad out, and you should be able to see the dust ruffle. The dust ruffle goes under the mattress pad and hangs like a skirt on the bottom of the bassinet. Pick up the dust ruffle and untie any ribbons that might be used to anchor it on the sides or bottom area. Depending on the bedding set you bought or are using with the bassinett, the piece that goes around the hood area might have elastic to keep it snug, or if you are using the default that came the model that is sold in California, US - its not really removeable without a lot of trouble and other problems - (I would suggest leaving it on unless its REALLY soiled).
Jun 07, 2011 | Eddie Bauer Musical Rocking Bassinet...
I took the cover off to wash it and now i can't seem to get the cover back on correctly
It's easy. Hold the main skirt fabric and drop the pressboard support into the bottom with the feet/nubs down away from the inside. Now the metal frame drops in and next slide the hinged U supports outward. This raises the edges and gives height to the bassinet. The U supports either lock under a plastic clasp on the pressboard or sit into holes on the board. Now button down all the buttons around the interior. Set it back on the frame and snap the bassinet to frame snaps on. Add the hood and baby's new, clean bed is ready for a lullaby. Good luck and if you would like, go to the link below and get a free manual.
Just put in your model number 18270 and a PDF version will be offered. I would save it to your computer for future reference. Choose SAVE or VIEW...but I would save it too.
Kolcraft Instructions Link.
Mar 26, 2011 | Kolcraft Light Vibes 18270 Crib
Can put back together after washing the fabric ?
Mar 22, 2011 | Kolcraft Tender Vibes 18189-TX Crib
Once I have the cloth attached to the cardboard part can't figure out how to put it on the crib?
It's easy. Hold the main skirt fabric and drop the pressboard support into the bottom with the feet/nubs down away from the inside. Now the metal frame drops in and next slide the hinged U supports outward. This raises the edges and gives height to the bassinet. The U supports either lock under a plastic clasp on the pressboard or sit into holes on the board. Now button down all the buttons around the interior. Set it back on the frame and snap the bassinet to frame snaps on. Add the hood and baby's new, clean bed is ready for a lullaby. Good luck and you should be able to download a PDF version of the instructions from the maker. Just go to their site and search.
Mar 09, 2011 | Kolcraft Cuddle 'n Care Bassinet
Need instructions for assembly and how to remove skirt for cleani
I have a bebe fina kidsline bassinet that I am reusing and I need assembly instructions?
Jun 05, 2010 | Kidsline Millennium Collection Crib
Instructions for delta portable baby bassinet
May 09, 2010 | Delta Portable Baby Bassinet
How the hell does the skirt go on this piece of ****?
Put the metal frame on the board - then turn them upside down. The skirt has four slits - where the knobs on the bottom of the board come through - pull the material tautly while snapping on buttons.
Mar 17, 2009 | Kolcraft Light Vibes 18270 Crib
Eddie Bauer Musical Rocking Bassinet 10330WOW Crib Logo
469 people viewed this question
Top Eddie Bauer Baby Gear Experts
superdad1976
Nikki  Mclean
Nikki Mclean
Are you an Eddie Bauer Baby Gear Expert? Answer questions, earn points and help others
