Hoover C3820 SteamVac Upright Wet/Dry Vacuum Logo
Posted on Jan 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hoover Steamvac Model C3820 Clean Solution tank leaking
I have a Hoover Steamvac Model C3820. The Clean Solution tank is leaking.. looks like the black stopper maybe broke or missing an end (I have the spring) I have looked on hoover's page for the part (unfortuanly, the parts don't have pictures) Any idea where I could get a hardware diagram, or what the hardware in the solution tank is called?
usavacuum
Level 2:
Scholar:
  • Expert 57 Answers
  • Posted on Feb 21, 2010
usavacuum
Expert
Level 2:
Scholar:
Answers
57
Questions
Helped
29486
Points
103
What causes my hoover steam vac clean solution tank to leak?
Check the seals on the machine, most times they aren't sealed right. Lift and reset the tank and if that doesn't work, you need to replace them.
Hoover SteamVac LS F5899-910
Did you try to clean first the unit..
1helpful
I just bought a hoover steam vac model F5914900 and the clean water tank is leaking. I tried pressing the clean surge button and the trigger button that was suggested by someone else but it won't
Go to Hoover.com and find a local Service Station. They will replace it at no charge. MUST be a warranty location to get it free. Take your sales slip with you.
2answers
My hoover steamvac wont **** up dirty water float
Check your filter screen insde the upper tank. if your model has a wrap around filter try to pull it down about 1/2" to maximize air flow.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Hoover Steam Vac V2 Deep Cleaner leaking clean water
Fill the tank and determine if the plastic is leaking, or if the valves are leaking. if the tank is cracked, it would need replaced. There is an improved design now available.
You may cycle the valves on the bottom with the eraser end of a pencil.
2answers
My steamvac leaks from the clean water tank
try to look for small holes or cracks and even the tank.use clamps to make sure your hose is firmly attached.
3helpful
2answers
Recovery tank not working
recovery tank empty where do you look to see where the hair ball is so i can clean it
2answers
Hoover Steamvac Widepath 6500 leaks
You didn't give your model number, but if this is a V2, you may have a crack in the tank, alot of times it is underneath the seal on the bottom. Or the plunger at the bottom of the tank is stuck open or missing.
Top Hoover Vacuums Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
