Question about Ricoh Aficio IS01 Flatbed Scanner
I need a twain driver for a Ricoh IS01 Scanner... where can I find one?
Posted by heber617 on
Anonymous
  • 114 Answers
You can download it from ricoh.com then to download
Posted on Mar 19, 2010
I have ricoh aficio printer 1060 - windows 7-64bit. I can not define the scanner. twain
Only network twain drivers and only network scanner. Not possible to be used as scanner via usb.
Jan 17, 2018 | Ricoh Office Equipment & Supplies
I need driver for scanner and printer for ricoh nashuatec multifunction dsm415pf mashine for free
Hello!
You can use the scan-to-email or download the twain driver.
For that you can go to www.ricoh-support.com and download it.
See you!
Jul 05, 2011 | Gestetner DSm415pf Digital Imaging Sytem
I am trying to setup the 1515MF for network scanning. The manual tells me to go to scanner and select Twain on. But when I go to scanner features and then scan settings, my only choice is "default...
First download the twain drivers from Ricoh website or if you have cd down load it from it. Then from there when you go to scan should give you selection option for it.
Jan 05, 2018 | Ricoh Aficio 1515MF All-In-One Laser...
My cable that came with my ricoh is01 does not seem to be compatible with with my scanner and neither can I plug it into the pc.
The Ricoh IS01 uses a SCSI 2 (50 pin) interface. It should look like the one here: http://www.amazon.com/Cables-Go-03564-SCSI-2-Cable/dp/B000051312 . There are SCSI to USB converters but I'm not sure if you need a specific version. (Scanners require bidirectional communication with the computer so there were few interfaces that required a special connection.)
Depending on your computer's OS, there may be other issues. (Some may not be compatible with Windows Vista or Win7, for example.) Drivers for some OS versions are available here: http://www.ricoh-usa.com/downloads/downloads.aspx . Search for the IS01 (no other information is needed)
I hope this helps.
Jan 01, 2011 | Ricoh Aficio IS01 Flatbed Scanner
I can't get my Ricoh IS01 scanner to recognize the drivers that came with machine (windows 95 driver). I am running a windows xp system.
Microsoft drivers and installers have changed over time. The ISO1 drivers for XP are available here: http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/is01/is01en.htm . Click on the down arrow to download the one for XP and then double click on the exe file.
I hope this helps.
(NT or Win2K drivers can work under XP at times; Win95 drivers are less likely to work even in the compatibility mode.)
Nov 25, 2010 | Ricoh ISO1 400DPI Flatbed Scanner
How to Link Scanner from ricoh aficio 1232c
Download Twain Driver from ricoh site and you can use any softwere that suports twain scaning i use microsoft scan that comes with office 2003
Oct 18, 2009 | Ricoh Aficio 1232C Color Copier
Ricoh Aficio IS01 Flatbed Scanner Logo
356 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Bernard D'Souza
CheckitRight
CheckitRight
Timothy Van Der...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
