Question about Crosley 0187SST Turntable
My turntable does not spin - Crosley 0187SST Turntable
Posted by dbeard603 on
Anonymous
On my Crosley there is a switch on the back for either Phono or Aux In. Make sure it is set to Phono or the turntable won't spin
Posted on Mar 25, 2010
Francisco Mauricio G
    Genius:
  • 1,550 Answers
Maybe the belt are on bad conditions change it
Posted on Jan 08, 2010
When I push start button turntable doesn't rotate
Technics SL-QD33 doesn't turn - Vinyl Engine
www.vinylengine.com/turntable_forum/viewtopic.php?t=28381
Jun 3, 2010 - 15 posts - ‎3 authors
It powers up, lights come on but the platter won't spin. ... However when I press "start", nothing happens and the platter won't spin when ... the arm towards the record without pressing the "start" button. ... SL 7, SL-10... and / or any of the fully automatic Technics turntables using optical record detection......etc Marantz 6300 question...
Nov 21, 2009
Dual CS505 turntable won't auto-start
Aug 16, 2009
More results from www.vinylengine.com
Help!! My Turntable won't spin - AVS Forum ' Home Theater ...
www.avsforum.com/.../1316271-help-my-turntable-won-t-spin.html
18 posts - ‎7 authors
Dec 21, 2015 | Audio Players & Recorders
My turntable does not work on a audio component system
Is the motor on the turntable spinning - wiring misconnected?
If motor is running then th epower is not being transmitted to the platter by either a belt drive or a pulley drive.. The belt or pulley has to be replaced to restore the missing friction
Mar 14, 2015 | Audio Players & Recorders
Turntable won't spin, even after switch the tonearm right
Hi, most likely the belt has come off or is stretched. Cheers John. Styluscity
Nov 22, 2012 | Crosley 0187SST Turntable
Why does my turntable not spin when I move my Tone arm over?
Hi Daniel, its a bit of a long shot however try this. With the turntable powered of manually rotate the platter approx 12 times to reset the auto operation back to default. John styluscity.com
Nov 30, 2011 | Sony PS-LX250H Turntable
Has power but wont spin
Hi,Dead as in no power up or dead as in the turntable will not spin?? If the turntable isn't spinning check and see if you have a direct drive or belt driven.Getting back to your turntable, if it is belt driven your belt may have become dried rotted. replacements are available at
elexatelier.com/ ,
elexatelier.com/ or
needledoctor.com ... good luck, definitely worth getting it up and running again...
Have a nice day..
Feb 17, 2011 | Numark TT200 Turntable
Turntable spins too fast at both speeds
this is belt driven turntable....have you tried adjusting it via the pitch control or even getting another belt for that turntable....
Apr 12, 2009 | Audio Technica AT-LP2D Turntable
Turntable will not turn (spin)
It would appear this is a belt drive turntable - here's a link to a site where you can order a replacement, although you may be able to find a cheaper one.
http://www.elexatelier.com/panasonic.htm
Hope this helps!
Mar 25, 2009 | Panasonic Audio Players & Recorders
Crosley 0187SST Turntable Logo
824 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Robert Marmorstein
Level 1 Expert
efs_perpends
efs_perpends
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
