Question about BenQ FP91G+ Monitor
My fp91g+ flashes a green light (sometimes) when the power switch is pressed... but doesnt power up monitor has been reliable for over 2 years and simply quit working.
  • 11,361 Answers
Normal failure for 2 years old monitor, sda but rue. Look for bad caps, see example of failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Posted on Jan 08, 2010
6ya staff
SOURCE:
My Nikon Coolpix S220 camera getting problem. Upon the power switch press to ON the power-on lamp (green lamp)blink for few minutes but the LCD monitor never turn ON. After the green lamp OFF then the...
I cant detect my pics in my laptop from the sd cars. But I can see in my camera when I insert the same sd card. Is there any problem with sd card or any virus effected? How to upgrade the sd card. please help me out.
Feb 01, 2011 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Hi My Benq FP91G flickers with the auto syncing message around once every 60s. sometimes the power button does not work, i have to keep pressing it before it will eventually switch on. Is this worth...
Its worth fixing...
Its just an issue with the board.
If it happens to be the LCD panel, rather not fix it since its gonna cost u a fortune.
Oct 11, 2010 | BenQ FP91G+ Monitor
Benq FP91G 19'' fades out
Capacitor problem on the power board internal solder fix is possible.
Jan 31, 2010 | BenQ Computers & Internet
The printer flashes orange light five times, and green once
Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
This also applies to the i550, i560, i950, i960
Sep 07, 2009 | Canon BubbleJet i560 InkJet Printer
Envision Monitor 22", when plug in the power core, the Green power light would blink repeatedly non stop. Screen would show nothing just a blank screen... it a one year old monitor, and was working fine...
Hi, when connected to a portable you sometime must hold function key then press F5 or F6 to switch between the portable screen and the aux monitor, have you tried the monitor with another computer. If this does not work, it might require internal repairs...
Aug 13, 2009 | Computers & Internet
Dell E173FPC Monitor stays black and the Power switch cycles
You need to disasemble and check for dry or burn capacitors first then check for the transistors near the inversors.Good luck
Apr 03, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Not on
try eBay ressurectek for repairing you inverter/power supply board. If you have the one transformer (q9b-2) version, he says he can fix it.
tom
Sep 26, 2008 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Acer AL1912 sometimes doesnt start
Try reseating your cable connections. While you have them off, take some compressed air and clean both the connection ports on the back of the computer and cable connections. Check to make sure there are no bent pins on the cable connectors. If you know how, you might also want to open your computer case and reseat your video card and clean your system out with the compressed air. Make sure your computer is completely shut down properly and is unplugged from the outlet when you do this and before you work inside the case make sure you touch the metal side to discharge any built up static electricity you may have so that it does not cause damage to the sensitive components inside your system. If possible you might want to take the monitor and connect it to another computer system, if it works properly on that system, more than likely it might be your video card. Hope this helps
Jun 25, 2008 | Acer AL1912 19" LCD Monitor
Power button flashing green on and off. No Picture
What type of monitor do you have? I need to no if the power supply or cord plugs directly into the LCD Monitor? These questions are important! Please answer these questions, I will be able to give you an answer!
Nov 25, 2007 | Acer AL1916W 19" LCD Monitor
BenQ FP91G+ Monitor Logo
144 people viewed this question
Top BenQ Computers & Internet Experts
Ekse
Joaquim Martins
Karan Sethi
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
