Whirlpool Range / Stove / Oven Fault Codes
Failure Code
Fault Code Description
Solution
4 Digit Failure Codes (for 2 digit codes see below)
F1 - E0
EEPROM communication error
1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Note: Applies to all F1-E... codes except F1-E3.
F1 - E1
EEPROM checksum error
F1 - E2
UL A/D error(s)
F1 - E4
Model ID error
F1 - E5
Calibration shifted
F1 - E6
Latch signal mismatch error
F1 - E9
Stack overflow
F1 - E3
Wiring harness cavity size does not match previously stored value
The "Cavity Size Select" jumpers in the wiring harness indicate a cavity size different from that which the control was previously configured for. Check the jumpers in the harness to make sure they agree with the actual oven size.
Posted on Jan 09, 2010
