Question about iLO MP3 Player
I have a iLO MP3 player that accepts SD cards. The player version is 3.120.GO2. It will not switch to the SD card for its memory. It doesn't matter what size or type of card I use.
Anonymous
    New Friend:
I Solved the problem by using a more up to date player.
Thanks
Posted on Jan 09, 2010
My memory card does'nt want to accept files or delete them. When i send files to it,it says it is write protected
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
2answers
I know that some older devices can't use the newer HD SD cards. What kind of SD card should I buy for this player?
It supports Micro SD Card.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards Anand
Memory card inserted not downloading music to the player
try putting a folder on the sd card name it Music then put your music on that
1helpful
2answers
Compatibility of sd and sdhc
no this device is SD and MMC only
http://www.amazon.com/iLo-Player-Cherry-MP-556-MP556/dp/B0018ZA2V8
Check your spec, sorry
Regards
Richard.
Ilo MP 3 Model MP-556
Check the owners manual for limitations on the external memory. Sometimes the MP3 player has a limit on external memory. Lets say 2 GB. Also make sure the lock switch is disengaged. Also try to reformat the player.
Ilo go2 mp3 card reader problem
when the memory is full, this one will all of a sudden only read a smaller card size - delete some of the songs
1helpful
2answers
Memory full but noting on it
try formatting the internal memory
2GB SD Card Problem.
you cant expect all mp3 players to play as many songs as u wnt. each mp3 player has a limit of memory card that needs to be attached. see whats the maximum memory your mp3 player can support. and also see if you can locate all the songs when the SD card is connected to your computer
I bougth a 4GB SDHC card for my 1 GB ilo w/expansion slot, will it work
my new ilo 1gb mp3 player's manual reads: you can use up to a 1 gb sd or mmc card. hope this helps. :)
Memory expansion slot
If the SD card is a compatible type, it should just read it
Top iLO Audio Players & Recorders Experts
Marvin
Marvin
Tom Chichester
Vinho Xie
Vinho Xie
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
