Question about Toshiba Satellite Pro A200-EZ2204X Notebook
My Toshiba Satellite Pro A200 works fine if I use a battery charged on an identical machine, with the same mains charger. With the mains charger plugged in it either shows 'plugged in not charging' or 'plugged in charging' but the battery never charges. I always have to charge it on the second A200. If it's showing 'plugged in charging' with the mains connected and I remove the battery, the machine switches off immediately. Any ideas anyone? If it's a component problem, maybe I could use something from the second unit that has a motherboard problem of its own! Any ideas or help appreciated. Thanks Paul
Anonymous
    Sergeant:
  • 309 Answers
It sounds like the connector from the A/C adapter to the motherboard is loose or the inside of the adapter plug that attaches to the motherboard is defective.
Posted on Jan 08, 2010
Testimonial: "Thanks for the super quick reply. I was thinking along those lines. I'll take both units apart and compare them. Cheers Paul"
Anonymous
    New Friend:
My Toshiba A200 satellite pro will not switch on. It goes straight to hybernation mode and I cannot recover it. Any ideas?
Posted on Mar 06, 2010
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
The headphones on my Tosiba Satellite Pro A200 dont work
it might be hardware technical problem.. i think headphone censor in the port is not working get it repaired from local service centre
Oct 01, 2009 | Toshiba Satellite Pro A200-EZ2204X...
WILL NOT TURN ON WHILST BATTERY POWERED
please try and update your BIOS
http://nordic.computers.toshiba-europe.com/innovation/download_bios.jsp?LNG=18&service=ND
i can send you the direct link for the download if you tell me what short model number your computer has. you can read this under the computer PSAExx
May 27, 2009 | Toshiba Satellite A200-19501F Notebook
How to remove bios password for Toshiba Satellite A200
If you know the current password, use it to enter BIOS SETUP.
Then, type a "blank" ("space-bar") as the "new" password.
If you don't know the current password, you're stuck;
this is a "security" feature to prevent a stolen laptop from being used by the thief.
May 27, 2009 | Toshiba Satellite Pro A200-EZ2204X...
Toshiba Satellite Pro A200 prob after Antivirus 360 trojan remove
it seems that some files are still there and it is not allowing IE to work properly.
try to install Firefox, opera or avant browser and try to browse.
or in other case try to ping from command prompt
and check the IE properties.
hope it will help you
Mar 24, 2009 | Toshiba Satellite Pro A200-EZ2204X...
Toshiba satellite pro a200 my laptop has stop recharging i don't know if its the adapter or the battery
It might mostly be the charger that has gone bad or check inside the DC in plug on ur machine and see that its not broken if not its the charge control chip that has gone bad
Sep 04, 2008 | Toshiba Computers & Internet
No power in toshiba satellite pro m70
You need to check ur power sockets,
ur charger whether its working,
and test the battery,
also try to switch it on when there is no battery attached to it by just pluging the charger straight
Mar 17, 2008 | Toshiba Satellite Pro A200-EZ2204X...
Toshiba Satellite Pro A200-EZ2204X Notebook Logo
Top Toshiba Computers & Internet Experts
k24674
Michael Thomas
Michael Thomas
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
