Question about Jacuzzi Signa 6 Whirlpool JAC-B540...
Faucet placement on Jacuzzi 6036
I am purchasing a Jacuzzi 6036. Is it possible to place the faucets on the corner of the tub itself, as opposed to putting the faucets in the tub surround.
Posted by bdrtheil on
  • Anonymous Mar 16, 2014
    Can't get cover off
NOT ME
  • 2,841 Answers
If there is room most definitely you can place the faucets on the tub itself. You can mount them on the left rear. However be very careful drilling the holes and make sure you have it aligned correctly before drilling. Check underneath to make sure there is enough room for clearance and hook up. Here is what it will look like. Faucet placement on Jacuzzi 6036 - a1da3ad.png
Posted on Jan 08, 2010
Need to know where the reset button is on Kohler jacuzzi tub
The only place I'd expect to find a reset button is on the motor itself. That is, unless it's a ground fault problem, in which case it might be on another ground fault outlet somewhere in the house (possibly a bathroom or garage outlet) OR on the breaker - check the breaker box to see if the breaker's tripped or the GFE button needs to be reset.
Aug 02, 2017 | Jacuzzi Home
Is it possible to buy somewhere the Optional "U-Frame Skirt" for a "Jacuzzi CIVA Whirlpool" bath tub? Anyone know where or other suggestions on covering the front?
Home Deport and Lowes each used to carry a generic front skirt for "jacuzzi" type tubs. You may find something at one of their stores that will work.
The other solution would be to contact a Jacuzzi Showroom for authorized replacement parts.
Dec 02, 2014 | Jacuzzi Home
Newly installed jacuzzi only has hot water for about 30 seconds, then water is tepid only.
This issue will have nothing to do with the jacuzzi tub. You will find the problem exists in the way your home was plumbed by the plumber.
Somewhere there is a clog in the water line going to the hot water faucet.
Find that and you will solve your problem.
Rod
US Parts Center
Mar 06, 2014 | Jacuzzi Home
My jacuzzi Waterfall faucet drips
Shut water off and remove knobs. Replace valves on side leaking. Go to Home Depo they will help.
Dec 03, 2012 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
I have a jacuzzi whirlpool tubs may of 2000 and faucet comes off when i start the water what could be the problem
check the allen screw which holds the faucet in place. if it is not tight enough the water pressure will blow it off the connector.
Jan 13, 2011 | Home
How do you remove Jacuzzi Waterfall handles to get to the valve. There are no visible screws??
On the top of each handle you will need a very small flat head screwdriver or something similar to "pop" the top cap off. Under that cap there is a phillips head screw so you can remove the handle.
Jan 10, 2011 | Jacuzzi Water Rainbow Tub Faucet ...
How do i install an jacuzzi that has no faucet its a bathroom jacuzzi has no place for faucet it just has a hole for drain handle
either mount on wall or need to drill holes through jacuzzi 99 % of tubs dont come with faucets
Apr 24, 2010 | Jacuzzi Home
I have a Jacuzzi Espree 6036 and switch will not shut off whirlp
Hello. yes you can replace the switch. All of the parts come with instructions. plus you can call the jacuzzi repair technician directly and have him/her talk you through the procedure at 866-905-2289. here is the owner manual in case you don't have one
http://www.guillens.com/jacuzzi/images/ESPREE.PDF
Apr 02, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
I have a jacuzzi corner tub. The control panel
I would expect there is a Jacuzzi dealer in your town and I would guess he has parts. If you purchase parts locally, not only are you helping your neighbor but also, you will have the opportunity to pick his brain on tips to install.
Thanks for your interest in FixYa.com.
Feb 20, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
I have the Civa Jacuzzi installed with the Whirlpool magic touch on/off switch. It was purchased in 1994. Where can I get the same replacement switch?
Possibly here...
http://www.jacuzziwhirlpoolbath-parts.com/bath/bath0034.html
I am looking to purchase a used Civa. How do you feel about the tub in general?
Feb 16, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Jacuzzi Signa 6 Whirlpool  JAC-B540... Logo
572 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Bill Johnson
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
