I've put a code for my ipod touch and it seems and i entered an additional number by mistake and i can't open it again, can u help me how to remove the code to use my ipod again
If it was locked and you donot know the password then the only thing you can do is restore it using dfu mode hold both power and home button until it turns off and restart and show you to connect to iTunes. Then restore it. Let me know what happened.
you can fix it by restoring it in iTunes. Here is a way to put it in recovery mode.
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Iphone
and itouch dfu mode Plug the
usb cable into the Ipod and NOT into the computer. Hold the
Home Button down for 5 second (do not release it) Then
Press and hold the Power Button for approx 10 secs (count them out) Your iPod
will reboot. Release
the power button and continue holding the Home button for an additional 27secs. You may
see the screen go blank or not. Plug the
USB end into the computer with itunes open. Your ipod
will mount in recovery mode. Restore
it and Your all set.
you will have to restore your ipod to factory default settings in itunes.
or you can jailbreak the ipod with software like quickpwn.
Here is how to restore your ipod in itunes.
You will need to put the itouch in DFU/Recovery mode to get it to connect.
Normal
0
font-size:10.0pt;
Plug the
if you need any further help let me know. Good Luck
i entered in my pass code and went on a vacation with out my ipod and forgot my pass code. is their somesort of universal code to enter to unlock my ipod? pllzz help me!!!!!!!!!!
i think that you should just keep on turning your ipod on and off until you can put in the passcode again then try to enter 0000 i think that is usually the code that most ipods have ok hope this helps
Try connecting the ipod to itunes, and setting restore. This will erase the code on the ipod touch. The ipod will allow this to happen with the last computer to sync to it.
Also make sure you have the latest itunes version installed. www.apple.com/itunes
and also that you have the latest ipod firmware. This can be done by selecting "check for update" from the ipod page in itunes.
just hold down the home button, then turn the ipod off, turn it back on, while your still holding the home button. The itunes will then detect it and you will be able to enable it
From what I gather in your post, it seems that your touch has had too many wrong attempts at the passcode, so now it won't even give you the number pad to try again.
It is now necessary to restore the touch on the computer that was used to originally sync it, so you can reset your passcode and resync the data.
If you use a different computer, you will be able to unlock and remove passcode, but you will lose your data.
The link below will explain what I said a little better, and at the end of the article there is another link on how to actually update and restore your touch.
